Introduction: Display Distance by Ultrasonic Sensor and Upload to ThingSpeak
This toturial is under D-duino-B platform.
You can easily develop IOT projects by D-duino-B.
D-duino can easily connect to web, and easily to be programmed by Arduino IDE.
Its 1.3 OLED is very helpful.
Today I use D-duino control ultrasonic sensor and display distance successfully and upload to ThingSpeak
at the same time.
Step 1: Prepare
D-duino-B x1
Grove shield for D-duino x1
18650 battery shield V2 x1
Seeed grove ultrasonic sensor x1
Step 2: Connect and Programe
I put this code on my github.
https://github.com/lspoplove/D-duino/blob/master/G...
D-duino has its 1.3OLED which is using SH1106.
D1 is SDA, D2 is SCL. Here we use D7 connected to D-duino.
Check pin map you will find D7 is pin 13 if you want to programm under Arduino IDE.
Step 3:
Then you can check with ThingSpeak.
All the data will upload to ThingSpeak by WiFi.
Here I set it upload to ThingSpeak every 10 seconds.
If you want to program with this toturial.
Don't forget to get a ThingSpeal API number first.
And don't forget to fix WiFi and Password in the code.
