Introduction: Display Letters and Words on the Oscilloscope
"Why you do this ?" Because it's cool and it makes me feel so nerd. And everyone love nerds!
Step 1: What You Need to Do This
1 x oscilloscope with XY mode
1 x breadboard
1 x Arduino or a Fartduino or whatever you want that has a 16 Mhz ceramic resonator
And some wires
For the RC low passfilter:
2 x 10kohm resistors
2 x 0.1 uF capacitors
Step 2: Wire Everything Up
Do you really need explanation for this?
Step 3: A Little Bit of Boring Theory
The RC low-pass filters are used to remove the jitter of the 2 PWM signals. The PWM signals jump from point to point and the interpolation between them is made by the charge/discharge curve of the RC circuit.
If you need more information go to the creator's website where you can find also the code http://www.johngineer.com/blog/?p=648. I just picked his code and modified it.
So what you do now? Take a paper and start drawing what shape you want to see on the scope. You need to draw it on a graph and write down the x,y coordinates and multiply them x10. The more points you have, the more precise will be your image BUT the flickering on the scope will be HIGHER so if you have a lot of points to draw try to use for the low-pass filter 8.2K and 0.047uf instead. To improve your shape also set ON the Persist parameter of the scope
Step 4: About the Code
#define NUM_POINTS 19 // our tree is defined by 19 x/y coord. pairs
Replace 19 with how many points your shape has. For example to create my A i used 16 points.
// x coords for drawing the tree (in rough clockwise order, from bottom)
unsigned char x_points[NUM_POINTS] = { 30,40,50,60,70,90,100,110,120,100,70,60,90,95,55,50};
// y coords unsigned char y_points[NUM_POINTS] = { 30,50,80,100,110,100,80,50,30,30,80,50,50,40,40,30 };
The comments say all. You just input your coords here in the right order (clockwise starting from the bottom).
These coords will give you an A instead of a christmas tree!
Step 5: But You Said a Text Also
Yes this is what i said. And look this is what it came out! I know it's ugly BUT with a little more patience than mine you will came up with a nice and clear text. Just make more points!
