Introduction: Distance Meter
This meter was developed using Arduino Uno, HC-SR04 sensor and a 16X2 LCD display for displaying each measurement.
Step 1: Bill of Materials
1 Arduino Uno
1 HC-SR04 ultrasonic sensor
1 16x2 LCD Display
1 Arduino Uno Proto Shield
1 Headers
1 10k Ohm Square Cermet Potentiometer
1 USB 2.0 Cable
1 Enclosure for Arduino Boards
Step 2: Schematic
This is your diagram so that you follow step by step the project in its essence.
Step 3: Assembling the Project
I installed the 16X2 LCD display into the Arduino PCB using the headers and also installed the HC-SR04 sensor. I used red and black heat shrink tube for connecting to +5V and GND respectively in this sensor while connecting trigPin to arduino pin 12 and echoPin to Arduino pin 13 for completing this operation.
Step 4: Joining the Parts
Mount what you completed in the previous step on your Arduino Uno.
Step 5: Upload the Code
//Code
#include <LiquidCrystal.h>
LiquidCrystal lcd(11, 9, 5, 4, 3, 2);
#define trigPin 12
#define echoPin 13
int duration, Distance;
void setup() {
Serial.begin(9600);
pinMode(trigPin,OUTPUT);
pinMode(echoPin,INPUT);
lcd.begin(16,2);
lcd.setCursor(0,0);
lcd.print( "Distance:" );
void loop() {
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
Distance = (duration/2) / 29.1;
Serial.print(Distance);
Serial.println(" cm");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(Distance);
lcd.print(" cm");
delay(500);
Step 6: Code Uploaded
For uploading the code, you should copy and paste the code in the previous step.
Step 7: Enjoy Your Project
Enjoy your project by measuring distances with this amazing meter.
