Introduction: Diy 3 in 1 3d Printer | Machine CNC Machine, 3d Printing Machine, Laser Engraving Cutting Machine
Hey guys, briefly one of young age days have been wordering which machines are employed in production of 3d designing technology after doing alot of research I realized that 3d printer, cnc machine, laser engraver are the most employed in manufacturing companies and industries looking in there prices I was shocked that I could not afford purchasing one so I went for the say "if you purchase it make it" and you guessed it we are building it, in today's project we gonna build a 3 in 1 3d printer cnc laser engraver cnc machine all in one machine, so follow the steps and images keenly and build yours, too
#3dprintingmachine #printer diy 3d printing machine, diy cnc machine diy laser_engraving machine
For videos about the machine watch this channel
IMAGINATION AND INOVATION TV
LINK🔗 https://m.youtube.com/@imagination254
https://m.youtube.com/watch?v=cnbCvqcKTdU
What you need
#tools
CNC machine /laser cutter to cut the body parts
Screws
Allen keys
#material to purchase
Stepper motor 5 pcs
Smooth rods 6pcs 10mm diameter
Smooth rods 10mm diameter 400mm
3d printer control board
(skr 1.4 turbo board)
Pulleys
Gt2 timing belt
DC motor 24v 755
Laser spindle
Nozzle
Heated bed 300mm by 300mm
Powsr suply 24v
Ect as show in the images for more understanding each part watch this video I hVe shown everything
https://m.youtube.com/watch?v=wVZYbnX4qOQ
https://m.youtube.com/watch?v=VvJQKu-0ynU
https://m.youtube.com/watch?v=ytn7MTrxJDU
Step 1:
Step 1 is to build the body, so grab your Allen key and 5mm screws together with your cnc cut parts I showed in the images that is the corner brackets insert the screws in the 5mm holes and use the aluminum extrusion, together with the t T nuts and assemble the body like in images
Step 2:
Step two is building the axis carriage, I I'll do that for three axis in the step 2 so have done x axis, y axis, and the axis to Vooid too long explanations
1 X axis
Take the x axis body part with you together with the screws,smooth rod bearings and screw them as per the image make sure they are friction free
To install the X axis in posit you need the z axis top and bottom holders as shown in the image so take them and install them on the body using 5mm screws and T nuts as shown in image
2 Y axis
Take the y axis part, the smooth rods bearings and screw the down and ensure that they are friction free to bearing from wearing out, this will be our bed where the work will be laid
After doing so there are stands parts as shown in the image install those on the body for you to install the y axis you need them for they hold the smooth rods as shown in images
For Z axis
Take the z axis two body parts as the printer is very big we are using two motors on z axis then add all the parts needed that is stepper motors for x axis, smooth rod bearings on both parts as shown in the images
