Introduction: Diy Air Purifier
THIS IS A HACK FROM AIR COOLER TO AIR PURIFIER
this is so easy
you just need to add some layers of clothing and foam as primary and secondary filters
Step 1: WHY WE NEED ONE
air purifiers in the market are too costly
and stuff was lying around my house
this air cooler is of no use due to rainy season
the place where I live is very polluted and a lot of dust
thus i need some kind of purification system
all the urban areas are heavily polluted and thus you also need to make one
Step 2: What You Need
Foam sheet
cloth
velcro tape
air cooler or air conditioner
tools
cloth
velcro tape
tools
Step 3: Cut the Foam Sheet According to the Size of the Back Cover
make your cuts precise
Step 4: Cut the Velcro Tape
cut it in the size desired
Step 5: Stick the Velcro Tape
using hot glue gun, stick the velcro tape on the back cover and the foam sheet
Step 6: Cotton Cloth
take a thin cotton cloth
Step 7: CUT AND PASTE IT ON THE FOAM SHEET
make sure that you cut bit more on the sides to fold around the foam
stick together by using duct tape or staple them together,even you can sew them completely
Step 8: OUR FILTERS ARE ALL SET
using the velcro stick them to the back cover
Step 9: SLIDE IT IN
slide the back cover with new filters
we have got two filters one is primary nd secondary
Step 10: YOU ARE READY
made it
washable filters
reduced noise
give it a show off
washable filters
reduced noise
give it a show off
Step 11: Lets Test It
woooow man it works better than i expected
very less noise
perfect airflow
due to suction all the filters stick together
great air filteration
when tested it cleaned the room full of dusty air within 15 minutes
the water pump works perfectly fine and thus can be even used as an air humidifier too
you can add essential oils to its filters or water pump to get the air full of fragrance
very less noise
perfect airflow
Step 12: THANKS FOR WATCHING
VOTE FOR ME IN THE CONTEST
FOR ANY QUERIES COMMENTS ACCEPTED
be sure to check out my other instrutables
