Introduction: Diy Mini Captain America Shield
My social media
Twitter: https://twitter.com/Robotriks
Facebook: https://www.facebook.com/Robotriks-771225272982743...
My Blog: www.Robotriks.com
YouTube: https://www.youtube.com/channel/UCS3NNBMFOOPgozzi5...
Step 1: Supplies
-1 Empty aluminium can
-1 Wide elastic band
-1 sheet of paper
-1 glue stick
Step 2: Tools
-Pliers
-Hot glue gun (Optional)
-Rotary tool with sanding wheel or a metal file or sandpaper (You only need one of these)
-Scissors
-A printer
-A computer or cellphone that can send files to the printer
Step 3: Step 1: the Aluminium Body
-Using a Rotary tool and cut off wheel or maybe some tin snips cut off the rounded part of the can bottom.
-Next cut 8 slits about 2-3 mm in length.
-Using pliers fold down 6 of the flaps leaving up two that are across from each other.
Step 4: Step 2: Add the Elastic Band
-Cut a piece of wide elastic band about 5 cm in length.
-Place one end of the elastic into one of the open flaps and fold the flap down over the elastic using a pair of pliers.
-Place the other end of the elastic into the other flap and fold down the flap over the elastic.
Step 5: Step 3: Add the Design
-Print off the picture of the shield found above. (the design should be 4.5 cm in diameter)
-Cut out the design.
-Hold the piece of paper up to some light and mark the corners. (as shown in picture)
-Connect each of the inside marks to the opposite outside mark. (as shown in picture)
-Cut along each line leaving a small amount of space in the middle so that it doesn't fall apart.
-Cover the outside of the aluminium shield in glue and place the paper design onto it making sure that the design is centered.
-Push down the edges and adjust the wedges so that the wedges are evenly spaced out with zero space in between.
-(Optional) Put a small ring of hot glue around the edge of the design to hold it down and make sure it does not come off.
Step 6: You Are Done!!!!!
Feel free to leave any questions or comments in the comments and please like this instructable and vote for me in the contests as well as follow me on social media
Youtube: https://www.youtube.com/channel/UCS3NNBMFOOPgozzi5...
