Introduction: Diy Offline Grbl Controller V2
this is basically a remix of David T660 project on the offline controller, i added an sd card reader to process Gcode files directly through the controller if you want to keep your computer away from dust or you want to keep it in a seperate place
the project is not yet complete , i did a simulation and it works , i still have to make a case for it out of plexiglass (acrylic sheets), i'll share the final results whhen the project is finally done
- Arduino Nano (ATmega328)
- I²C 20×4 LCD with I²C backpack (address 0x27/0x3F)
- 4×4 membrane keypad (8-pin)
- microSD module (SPI)
- 3018 Pro CNC controller board (running GRBL)
- Dupont male-female / male-male jumpers
- Breadboard, 5V power supply, small enclosure, soldering iron
Step 1: Step-by-step Assembly (prototype / Bench)
- Power off everything.
- Mount the Arduino Nano on the breadboard so VIN/5V/GND and digital pins are accessible.
- Connect the I²C LCD: SDA→A4, SCL→A5, VCC→5V, GND→GND. Tighten the contrast pot on the backpack if characters are faint.
- Wire the keypad according to the keypad table above (D2..D9). Secure keypad on panel or tape it to the board.
- Wire the SD module: CS→D10, MOSI→D11, MISO→D12, SCK→D13, 5V→5V, GND→GND.
- Double-check all grounds: the Arduino, SD module, LCD and (later) CNC board must share the same GND.
- Upload the sketch to the Nano via USB. (Do not connect GRBL RX/TX yet.)
- Test LCD & keypad: open Serial Monitor (if desired) while Nano is USB-connected. On power-up the LCD should show XY step / Z step / Feedrate and SD Ready/Failed message. Press keys and watch values change on LCD.
- Prepare SD card (see next section) and insert into module. Press B on keypad — first 3 file names should appear on LCD.
- Connect TX/RX to GRBL only after code uploaded and SD testing finished: Arduino D1 → GRBL RX, Arduino D0 → GRBL TX. Also connect Arduino GND ↔ GRBL GND.
- Power the CNC (motors power supply) and ensure the controller board is ready. With everything connected, press A to stream test.gcode (or chosen file) to GRBL. Start with small safe moves.
Step 2: SD Card Prep & Sample Test.gcode
- Format the SD card as FAT32 (for cards >2GB choose FAT32).
- Place a file named exactly test.gcode at the SD root.
- Use plain text, unix line endings (LF) or CRLF — the sketch trims lines so CR is removed.
- Sample safe test.gcode (incremental mode to be safe):
Put that file on the SD card, insert it into module and press A to run (the code runs test.gcode).
Step 3: How to Test Safely
- With Arduino connected by USB, confirm LCD displays values and that pressing digits updates values (XY step, Z step, Feedrate).
- Insert SD card and press B to list files (if SD Ready was displayed).
- With SD OK, power down USB debug connection if you plan to connect Arduino TX/RX to GRBL.
- Connect Arduino TX/RX to GRBL RX/TX and CNC GND common.
- Power CNC motors and controller. Keep hands clear of moving parts.
- Press A to start streaming test.gcode. Watch the CNC do small moves. Be ready to cut power if anything is wrong.
Step 4: Important Safety Notes
Always start with very small moves and low feedrates when testing.
Keep a physical emergency-stop or kill-switch accessible.
Never rely solely on the software for safety — power off if motion is unexpected.
If your SD module is a bare microSD breakout (no regulator/level-shift), do not feed it 5V — use 3.3V only.
