Introduction: Diy Origami Organizer Box Without Glue
Hi Friends! In this project, I made an amazing, easy origami organizer box. This is really so easy and without glue. I made a desk organizer box.
Step 1: Cut:
First I cut a square sheet of paper from A4 size paper.
Step 2: Fold:
Fold the corners of the paper. (1 and 2 edges overlap) It will be in the form of a triangle.
Step 3: Rotate:
Rotate the triangular paper 45 degrees. You can determine the direction according to the numbers in the photo.
Step 4: Fold 2:
Fold the sides of the triangle to the middle. So you will get a square shape. You can follow the numbers.
Step 5: Turn and Fold:
Turn over the back of the new square paper. Then fold only 2 layers of paper (at the bottom corner of the square) upwards.
Step 6: Unfold
Unfold all the parts you have folded and make the triangle in step 3 again.
Step 7: Triangles:
You need 3 of these triangle. I did it in different colors. But you can also use paper of the same colors.
Step 8: Numbers:
I wrote numbers on the left and right sides of the triangles. These are very important. This stage will create the organizer.
Step 9: Inside and Outside:
The number 2 side of each triangle will go inside the corner number 1 of the paper on the left side (according to the photo).
Step 10: Inside 2:
This rule applies to all edges. "The number 2 side of each triangle will go inside the corner number 1 of the paper on the left side (according to the photo)."
Step 11: Fold All:
The organizer will look like a bowl. Turn the bottom. Interlace the corners of the paper to form the bottom of the bowl. For example: fold the yellow paper, then the blue, then the green, then the yellow, and again the blue and green paper.
Step 12: Ready:
Organizer is ready. You can do it by using colorful, or just one color paper.
Step 13: Finish:
I made a bowl-shaped organizer without using any glue, tape, etc. Although it may seem difficult, you will find that it is very easy when you start doing it.
Step 14: My Video:
This is my video about this project. You can also see all steps and all important details in this video.
20 days ago
4th view
