Introduction: Diy Seven Segment Display Clock
in this tutorial, I am going to show you how to build a seven-segment clock
Step 1: COMPONENTS
- 4* common anode seven segment displays https://amzn.to/3aDfwtP
- Arduino UNO https://amzn.to/2VXJOlO
- 3 push buttons https://amzn.to/2KxexB8
- Ds1307 rtc module https://amzn.to/2zmkG0p
- Common PCB https://amzn.to/3cPaNXP
- 2*leds https://amzn.to/2VSgkWB
Step 2: Cicuit Diagram
As the name indicates seven segment displays has 7 segments. each segment is a single led and all the 7 LEDs connected together with a common pin that may be a common positive or a common negative and arranged in a specific style.
A typical 7 segment display has 10 pins arranged in top and bottom each of middle pins are common pins
And others are to control corresponding seven segments
Step 3: Setting the Displays
we have 4 displays that is totals of 4*8=32 pins to control this our Arduino doesn't have 32 pins so how to do this. yes, multiplexing...
so we connect all segments together that is segment A of 4 displays together, segment B of all displays together and soo on ... now we have 7 common segment pins and 4 common anode pins that is total 11 pins yes our Arduino has 11 pins .by using multiplexing lets control 4 displays with 11 pins instead of 32
Step 4: Connections
I connected everything according to the circuit
connect one end of 3 push buttons together and connect to A0, A1, A2
RTCmodule works on i2c communication so connect
SDA TO A4
SCL TO A5
GND TO GND
VCC TO 5V
Step 5: Testing on Breadboard
I connected everything according to the schematics and everything work perfectly
Step 6: CODE
download upload
Step 7: REPLACING THE ARDUINO UNO WITH HOMEMADE ARDUINO
to save some space I removed the Arduino and repaced with my homemade Arduino
watch this video to know how I made my Arduino board
Step 8: Making the Case
i used 3mm foam sheet to build the case
Step 9: Happy Making
if you have any doubt about this project please comment below
please watch the videos for more details tutorial also subscribe to my channel. thanks
