Introduction: Diy Shaker Birthday Card
This adorable cute card i had made for my brother in law .
Here you will find step by step tutorial of diy shaker birthday card. This tutorial is inspired by lawnfawncards...
So lets make-shake-create...
Happy crafting..
Step 1: You Will Need
Black and white cardstock
Scissor
Quilling paper strip
Punch
Watercolor paper
Glitter tape
Glue
Scale
Acetate sheet
Sequins
Beads
Glitter
Sharpie
Glitter frames
Double sided adhesive tape
Step 2: Prepare Your Base Card
-I took 16" by 12" plain black cardstock and fold it into half lengthwise using scorer.
-Final size of the base card will be 8" by 6".
-i dont have any scrapbook paper having black and white combination. So i have to made this using single hole punch and black quilling paper strips. ( i know its quite tedious job.) so if you are lucky enough and you have that black and white scrapbook paper you can omit this step.
-i scored 1/2" smaller in size rectangle on white cardstock.
-then using single hole punch i make black dots and create polka dot background.
-for stripes i have used different size of black colored paper quilling strip.
Step 3: Making of Shaker Window
- i used 5" by 3.5" glitter frame for the front of the shaker window.
- Cut water color paper in same size of the glitter frame.
- Its time to flaunt your imagination. I have decided to give a little birdy touch to my card. So using watercolors and sharpie i make cute designs on it.
- Now 1st put your designed watercolor paper .
- On its border adhere twoway tape. For giving extra height make two layers of double sided tape.
- Now keep sequins, glitter, pearls and beads in the frame.
- Cut acetate sheet of same size and put it on double sided tape .
- Apply glue on all the 4 sides of sheet and on it put black glitter frame and allow it to dry.
- Your shaky window is ready...
- Apply glue on the base card and put it on it.
- Your card is ready....
- Hope you all will enjoy it...
4 years ago
waoow its beautiful..
