Introduction: Diy Snowflakes With Flowers
Today I bring you this easy and beautiful craft for children, we are going to create a snowflake with very simple materials that we can have at home or go out to the park and get them, the main thing is the tree branches and flowers, as well as silicone and a little time, these flakes can decorate our room or the place you prefer we start!
Hoy os traigo esta manualidad tan fácil y bonita para niños, vamos a crear un copo de nieve con materiales muy sencillos que podemos tener en casa o salir al parque y conserguirlos, lo principal son las ramas de arbol y flores, ademas de silicona y un poco de tiempo, estos copos pueden decorar nuestra habitación o el lugar que prefieras empezamos!
Dry branches
White flowers
Scissors
Hot silicone gun
Nylon
Ramas secas
Flores blancas
Tijeras
Pistola silicona caliente
Nylon
Step 1: Cut the Twigs
We are going to carefully cut the twigs in different sizes, some longer than the others and observing the thickness of each one, remember that we are going to make a snowflake structure with them, for which many sizes will serve us.
Con cuidado vamos a ir corantdo las ramitas en diferentes tamaños, unas mas largas que las otras y observando el grosor de cada una, recuerda que vamos hacer con ellas una estructura de copo de nieve, por lo cual nos van a servir muchos tamaños.
Step 2: Cut Our Flowers
We are going to separate our flowers into small bouquets, this time we have chosen white ones that remind us of the color of the snow, just like with the dry twigs we are reserving the material to later assemble our flake.
Vamos a separa en pequeños ramos nuestras flores, esta vez hemos escogido blancas que nos recuerdan el color de la nieve, al igual que con las ramitas secas vamos reservando el material para luego armar nuestro copo.
Step 3: Create the Base of the Snowflakes
In this step we must be careful, since we are going to use the silicone gun, with the cut twigs we are going to create a structured base for the flakes. We start by creating a cross with two twigs and then a third, we are going to add different sizes to this base structure. Remember you can look for simple snowflake shapes and create them with the twigs
En este paso debemos tener cuidado, ya que vamos a utilizar la pistola de silicona, con las ramitas cortadas vamos a ir creando una estructora base de los copos. Comenzamos creando una cruz con dos ramitas y luego una tercera, vamos a ir agregando diferenes tamaños a esta estructura base. Recuerda puedes buscar formas simples de copos de nieve y crearlas con las ramitas
Step 4: We Paste the Flowers
As a final step we are going to decorate each snowflake structure with these white flowers, we help ourselves by placing the hot silicone on each twig and adding the flowers little by little, until we completely cover the structure, in this case we are going to leave some without flowers and we are going to tie some nylon to hang them in your favorite place. Ready with this we have finished our craft of flakes to decorate.
Como paso final vamos a ir decorando cada estructura de copo de nieve con estas flores blancas, nos ayudamos al ir colocando la silicona caliente en cada ramita y adicionando poco a poco las flores, hasta cubrir completamente la estructura, en este caso vamos a dejar algunas sin flores y vamos a amarrar un poco de nylon para colgarlas en tu lugar favorito. Listo con esto hemos terminado nuestra manualidad de copos para decorar.
