Introduction: Diy Sock Mask
here are the necessary supplies:
sock, coffee filter, scissors (or knife), needle and thread (or safety pins/tape)
DISCLAIMER:
This content is for educational purposes only. The author (OR AUTHORS) makes (MAKE) no representations or warranties of any kind (express or implied) relating to accuracy, safety, usefulness, usability, marketability, or performance of the content released here. The author (OR AUTHORS) disclaims (DISCLAIM) all express and implied warranties of merchantability, fitness of the content for a particular purpose, and non-infringement of any patent, copyright, trademark, or other third party rights in the content or in use of the content, or in the making, using, or selling of products or services by any person or entity. THE CONTENT IS RELEASED “AS-IS.” Anyone who uses the content in any way, including creating products or offering services, assumes all risk and responsibility related to those uses, including all risks associated with legal and regulatory compliance, safety, efficacy, performance, design, marketability, title, and quality.
Step 1: Preparing the Materials
Step 1: make cuts on sock like so to separate into three parts
also use remainder (top ankle part of sock) and cut into two skinny pieces as a sort of string (will fasten on face mask later)
Step 2: Connect Filter to Mask
Step 2: use your needle and thread or safety pins or whatever is at your disposal to connect the filter to the mask like so
then cut small holes on the top sides of the mask where the filter corners are as well as two at the bottom middle of the mask
this filter part is what makes your mask any better than just putting your shirt over your face
Step 3: Connect Mask Fasteners and Tie
Step 3: loop the string like pieces from the long part of the sock through each end of the mask where you cut holes. Two at the top and two at the bottom. Then fasten the mask on your face like so and tie tight to your desired comfort.
And now you're done!
