Introduction: Diy Thermal/Humidity Machine
Thermal Machine which helps to simulate desired environment inside to test the performance of an object thermally .
It can be hacked with humidifier for testing the humidity level.
It has two parts the left side is where the desired environment is simulated and the right side which contains the prototype or product to be tested.
once the experiment for the appropriate time we can test it with a thermal camera .
we have provided the arduino code, grasshopper definition to extract the graph .
Thanks to Angel Munoz and Alexandre Dubor from IAAC
Step 1: Infra Red - Light Simulating the Heat
Step 2:
Step 3: Connecting Relay and Arduino
Relay is connected with IR light , and Arduino .
Step 4: Arduino Code - for Two Sensors
Step 5:
Step 6: Epdm and Latch to Prevent Ambient Temperature Affecting the Experiment
Step 7:
Step 8:
Step 9:
Step 10: Thermal Camera Analysis of the Experiment
Step 11:
Step 12:
Step 13: Machine Fabrication
Step 14: Different Layers of Material to Insulate Explained
Step 15:
