Introduction: Diy Wood Engraving CNC Router
My first Wood Engraving CNC Router of 300 x 300 mm size and z axis travel length is 65 mm
Material :
- Aluminum frame with size 300 x 300 mm ( inside area of the frame)
- Arduino uno
- CNC shield
- Trapezoid screw 100 mm ( 01 no )
- Threaded screw or trapezoidal screw 500 mm ( 2 no. )
- Smooth rod ( 4 no.)
- LM8uu or SU8uu
- Nema 17 ( 3 no.)
- Motor 12V
- Mini chuck
- Drill bits
Step 1:
Step 2: My First Diy Wood Engraving CNC Router 300 X 300 Mm
Material Aluminum panel ( usually used in window panel )
Base Frame size. 480 x 500 mm ( inside area of the frame)
Step 3: Arduino UNO and CNC Shield V 3.0
Arduino UNO and CNC shield
Connection:
- Nema 17 ( 03 No's )
- Motor 12V , 30,000 r.p.m ( 01 No's )
- Adaptor 12V ( 02 No's )
- USB cable ( 01 No's)
Step 4: Sample of Wood Engraving CNC Router of Letter C of 20 Mm
Sample of wood engraving CNC router of letter C of 20 mm
Step 5: Second Sample of Letter E ( Pocket Inlay )
Second sample of Letter E letter size 20x 35 mm
Step 6: Z Axis
z axis
Travel length 65 mm
