Introduction: Diy Hair Jewelry-delicate Pearl Bow Hair Ornaments
In the post we’ll show you the way creating a pearl bow hair ornaments as your new hair adornments. Further, it can be made into a barrette, a clip or glued to a blank headband. You gotta love the diy hair jewelry.
Add more sparkles to your whole appearance by wearing diy hair jewelry on top, which may be actually simple yet effective. No matter you are using them for functional purpose or some else, such as achieve a coordinating dress-up, pieces of hair ornaments can make big difference. Use the pearls beads and strand of wire to create your own piece now.
Things need to make the hair ornaments:
Pearl Bead
Tiger Tail Wire
Hair Ornaments Finding
Glue
Side Cutting Plier
Flat Nose Plier
Pearl Bead
Tiger Tail Wire
Glue
Side Cutting Plier
Flat Nose Plier
Step 1: Take a 30cm Long Wire and Fold to Find and Mark Its Central Location.
Step 2: On Both Side, Slide on 10~13 Pearl Beads.
Step 3: Make a Loop With Two Beaded Wire Segments. Twist at the Marked Position. Finally, Tie a Tightly Knot for Secure.
Step 4: Add on Another Piece of Pearl Bead on Surface by Crossing With Two Exposed Wire Ends.
Step 5: Pull the Wire Tautly and Knot Again on the Back Side.
Step 6: Thread Extra 3~4 Pearl Beads Onto Each Wire Tail and Secure the Beads With Knots. Trim Off the Leftover Wires.
Step 7: Glue in Onto Your Hair Ornaments Findings.
When glued on the headband, they will be the hair ornaments that hold your hairs out of your face while adding a pop of color and special sense to an outfit. For those days when you need to dress up or attend a party, just take this diy hair jewelry and it may make you the cutest princess.
