Introduction: Dominoes Covered Coffee Table
As my old coffee table was beginning to show the ravages of time on its surface, I began looking for a cheap yet unique way to save it.
A while ago my sister and I saw a dominoes covered table (also here) and really liked the idea, so when a local shop sold a pack of dominoes for 3$ I went and bought 12 packs of them and went to work.
Step 1: Materials
Required:
- One table. To be lifted to new heights beyond the mundane for the glory of your living room.
- Sets of dominoes. Each pack contains 28 of them and mine measured at (4.7 * 2.4)cm. (1.85" x 0.94")
- Mighty glue. I used something called Montack by a company called Ceys that the guy at the shop recommended. for some reason the writing on it was in Spanish.
- A metal ruler or any straight object that will help move around the bricks when you do the pre gluing measures.
- a Bucket, to put all your dominoes in.
- A cat. They like to sit on the table and mess up any test arrangements you made. Later they might try to peel off the glued dominoes.
- Sanding paper or a sander if your table surface is not smooth (like mine was)
- Coloured Wood varnish and brush. Because I didn't cover the entire table, I wanted to restore some of the exposed areas.
Step 2: Preparations and Test Fittings
- Sanding
I didn't invest too much time into it because i knew i was going to paint it and of course cover it with dominoes.
- Test fitting.
It takes a bit of time but helps getting better results. Just drop the dominoes on the table - face up and start arranging them. For me this was when I learned that i didn't have enough dominoes to cover it all so I started creating various patterns - it also helps to see exactly how the table is covered so you wont be left with rough edges or missing blocks.
The ruler helps here a lot.
- Applying coats of varnish.
I applied 4 layers which helped to hide most of the damaged areas (that were not to be covered by dominoes). Work in smooth strokes following the grains and allow to dry according to the instructions on the can,
Step 3: Placing the Dominoes
- Create a guide column/row: According to your selected pattern and the test fitting, it helps if you begin glueing the dominoes in a manner that will create a core guide that you will follow. In my case I first created the middle column because everything else was to be aligned in relation to it.
Tips:
- My glue was very much like paste so I had to make sure it wont flow to the outside as I placed the dominoes, my method was to smear it on the side adjacent to the previous row so any excess glue wont be smeared on the exposed table.
- Not all dominoes are made alike.Our future Chinese overlords have a somewhat relaxed QA process when it comes to cheap items such as 3$ Dominoes sets. As a result there are some minute size variations in the bricks. Those minute variations could grow to big differences as you progress.Make sure that as you place each brick they are properly aligned and if needed, compensate for the size variations.
Step 4: Success!
This is the end of the work.
It took me about a day and a half including the varnish coating and numerous pauses.
I like it because it helped me make the table "mine" and unique. Plus the dominoes are serving as constant coaster.
Thanks to all who inspired this work and to my sister the QA by day, Designer whenever possible.
6 Comments
12 years ago on Step 4
I'm glad you included your cat helper!
12 years ago on Step 1
I loved your comment about the "optional but unhelpful" cat. I swear you made me laugh for 5 minutes!
12 years ago on Introduction
exciting exciting!!!
I am the sister!! this is very exiting!!
Neat setup! From the looks of 36 bucks worth of dominoes, one might be ahead to buy enough for full coverage. One thought I had - if you have access to a bandsaw with a fence and a featherboard-- the dominoes could be cut horizontally to make 2 - a front and a back, both with a neat view :D Great stuff! 5 from me.
I like it.
