Introduction: Don't Sleep, Let's Get Some Candy!
嗨,我來自台灣,今年13歲,英語不太好。請原諒我。
說明:此設備可用於報告和閱讀。將其放在前面,使用超聲波傳感器檢測距離,並確定您是否放置著(睡覺)。如果是這樣,則蜂鳴器將啟動並發出令人不愉快的聲音,減少睡眠感,並放下檸檬薄荷以刷新您的心情(在開始閱讀之前,在電機前放一個糖果),該設備還添加了一個留言板,您可以編寫提醒(例如:取出鑰匙)
紙箱,水桶,裝飾品,超聲波傳感器,蜂鳴器,伺服電機,糖果,電線,Ardunio板。
Step 1: Box
1. Choose the right box.
Step 2: Install the Device
2. Install the ultrasonic sensor, buzzer, and connect the servo motor wire.
Step 3: Install the Device
3. Adjust the position of the sensor to measure the approximate distance while sleeping.
Step 4: When Sleeping and Reading
Whether the test distance is accurate.(The photo shows the distance to the ultrasonic sensor when reading and sleeping.)
Step 5: Program
4.Write the sensor and buzzer first.
Step 6: Implementation
5.Actual implementation (result: the sensor was originally behind, and finally moved to the front).
Step 7: Fixed
6.Fix the upper layer of the box.
Step 8: Install the Motor
7.Add the servo motor program and find a suitable servo motor position.
Step 9: Try to Push the Candy With a Motor
8. Adjust the cardboard on the motor that assists in the fall of the candy, and actually test whether the candy can fall.
Step 10: Decoration
9.Decorative outer box(my idol).
Step 11: Finish
10.Finally finish!
