Introduction: Don't Throw Your Old CFL Into Garbage
Hayy guys
Here i'm explains simple way to reuse your old fused CFL.
PARTS YOU NEED
Fused CFL 5W (any range you can choose)
Wires
5W tube
Screwdriver
Insulation tape.
*This method is only used for fused tube & there is no problem in the circuit board.
Step 1: Open the CFL
Open the CFL using Screwdriver and remove the top tube part.
Check the tube using multimeter & make sure tube is fused.
Step 2: Give Connections to Circuit Board
Take out connections from circuit board using soldering iron.
Step 3: Seal the Cap
Seal the CFL cap using insulation tap.
Step 4: Connections for Tube
wires taken out from the CFL cap connect into 5W tube.
Step 5: New CFL Is Ready
Test your new CFL
