Introduction: Door Prize Ticket Belt
I made this belt out of a strip of door prize tickets and a pair of aluminum hard drive platter spacer rings. It's a quick project that also doesn't require much for supplies or tools. It's only good for the occasional use, and relies on the
- A length of door prize, amusement park, or raffle style tickets that's about 12 inches longer than your waist size.
- 2 hard drive platter spacer rings. (Thick ones work better than thin ones.)
- Clear packing tape.
- Scissors or a craft knife.
Step 1: Laminate the Tickets
I found that a good way to do this was to cut a length of packing tape that was a few inches longer than I needed, and then tape it down to a table with the sticky side up. Then I put the tickets with the printed side down centered on the tape. Finally, I folder over either side. This does leave a seam along the back that's visible on the tail of the belt. You could also place the ticket strip entirely to one edge and then fold over once. I put on a second layer, because my packing tape was thin. This isn't a belt that's going to last a long time, but gives a second life to both of the main parts.
Step 2: Attach the Buckle Rings
Now, slip both hard drive platter spacer rings though one end and fold the tickets back on themselves. I left about an inch of space and then wrapped a few loops of tape around to secure the loop. And now it's ready for wearing. Just put it on like a normal belt, push the tail through both of the rings, then separate the two rings and loop the tail back between them.
