Introduction: Double Origami Heart
This is my version of a Double Origami Heart made from a SINGLEBILL.
Items required for this project:
- ANY bill ($1, $2, $5, $10, $20, $50, $100, or if you're really crazy or have it around a $1,000 bill)
- time and patience
Step 1: Creasing
- To begin, start by using a crisp dollar bill.
- Crease the bill in half width wise.
- Then crease the bill in half height wise.
Step 2: Folding
- Take one side (in this case, the right) and fold it towards the center.
- Now in the front view, fold the bottom portion to the center of the bill.
- Repeat with the top portion of the bill.
Step 3: Shaping the Right Side
Once you have completed the initial crease and the fold, it's now time to shape the hearts.
- Crease one corner on the bottom portion of the bill.
- Repeat with the top corner.
- Lift this flap up and tuck the corner inside and flatten the crease you made.
- By doing that, this should create an extra flap. Bring the flap down towards you.
- Repeat with the top portion.
Step 4: Shaping the Left Side
- rotate the item 180 degrees and repeat the process for the other side by creasing both the top and bottom corners. (Note: image from prior step was used. I forgot to include the image. same procedure but different side.)
- Once you have completed shaping both sides, you should now have two pentagons that looks like a home plate in a baseball field.
- Next, pinch the center and fold the piece in half, and flatten one side.
- Repeat with the other side.
Step 5: Shaping the Hearts
If you are already lost, don't worry, I will follow up with a step by step video.
Please direct your attention to the rear portion of the item.
- While on the rear portion of the item, crease the upper left and right corners.
- After creasing the corners, look at the top view. It has three layers, for this Instructable and from the illustration, I will use #1, #2, and #3 for top (#1), middle (#2), and bottom (#3).
- Take layer #3 and fold it down and flattening the corner creases.
- After you made the necessary folds, swing each side around.
- Looking at the top again, it now has two layers (#1 and #2). Layer #1 is now the bottom since we swung the sides around.
- Crease the corners again and fold layer #1 down and flatten the corners.
- Once you completed the steps, flip it to the front and you should now see all four corners folded neatly.
- Looking from the top, only layer #2 is remaining. Look at the small pocket between the middle layer and bottom layer.
- Take the middle layer and insert it in the small pocket.
- Fold the remaining corners.
- You should now have 4 points. Turn the item around and fold all 4 points down.
Step 6: Arranging the Hearts
The hearts are now completed but are far apart. Here's the steps to bring them closer:
- Grab the thinner heart (you can tell the difference) and fold it backwards.
- Then grab the thinner heart in the center and fold it forward once more creating a Z fold. Note: you can bend and rotate the heart however you choose. Both hearts doesn't have to be aligned with each other.
Step 7: Step by Step (1080p HD) Video
Valentine's Day Challenge
7 Comments
2 years ago
FWIW UK notes are not as "wide" proportionally so you do not need the initial quartering. Also, you have to be quite generous as the new plastic ones explode their folds
Reply 2 years ago
sorry. I was under the impression that it would be US Bank notes. I would like to revisit this if I had UK notes. I know they have new plastic ones to avoid counterfeiting. If I get my hands on one next time, I'd try to make a demo using the UK notes.
10 years ago on Introduction
Hop I can follow the steps since origami isn't my forte but this would be perfect for sending my niece some cash for her birthday. I don't like giving cash in lieu of a gift but what do you give a 14 year old girl that works better than cash :)
take your time slowly and work on $1 bills only...heh. until you master it. you can watch the video if you're stuck.
Thanks :). I'll let you know how it comes out
This is awesome! Love that you included a video too. :)
thank you! Not sure if people would be confused with some of the steps and I tried my best to explain the steps. if they were confused with some of the steps, they could check the video on how to do it.
thanks for the comment :)
