Introduction: Double Glue Joint
About: Occupation: tech support
This technique was adopted directly from model rocketry construction.  It is a way to make strong glued joints for various woodworking projects you may work on.
Step 1: Materials
 - 2 pieces of wood (using wood shims here)
 - Wood glue (or Elmer's would work)
 - Spring clams or C-clams (Home Depot has them)
Step 2: First Layer of Glue
1.  Put a layer of glue on each piece of wood.
2.  Spread out evenly on each piece with your finger or brush.
3.  Let it completely dry.
Step 3: Apply 3rd Layer
1.  After the glue has completely dried, put a 3rd layer of glue on one of the dried layers.
Step 4: Clamp Pieces Together
1.  Before the glue dries, clamp the pieces together
2.  Wait until it dries before removing clamps.
3.  Fill in spaces with additional glue.
Step 5: Schematic
Quick schematic of the double-glue joint.
It should hold together strongly.
