Introduction: Double the Range of Most RBGs!
This is a very simple trick I thought of, that will increase the range significantly!
Step 1: Supplies
You must gather the supplies for the ammunition of the high powered RBG.
These generally come in any knex set, so just look around.
You need 2 elastics
You need 2 grey connectors
You need 1 white rod
Did I mention this is not my first instructable, so be nice!
LOL
You need 2 elastics
LOL
Step 2: 2 Is Better Than One!
Now you must tie the rubber bands together, and this might be hard for some unknown reason.
1: What you are making
2: Loop one through the other
3: Slide it through itself
4:Pull a bit
5:Tighter
6: TIGHTER!
This may be difficult for people with no hands.
4:Pull a bit
5:Tighter
6: TIGHTER!
Step 3: Slide Slide Slide!
Now you must slide the grey connectors onto the elastics.
Come on, what more is there to add?
Step 4: Finishing the Construction
The hardest part.
You must slide the elastic onto the rod, then clip one grey on.
Now slowly, slide the other one on, straighten it out and clip the other one on, done!
Step 5: Loading and Firing
Okay, you took the time to build this you better! And now you think, AHH! HOW DO I LOAD IT????
Well im nice. I am going to tell you.
Put the front on normally, then pull the greys back.
Separate them, then just put them on.
EASY!
As I said this is not! my first instructable, so be nice!
EASY!
