Introduction: Dragon Ball Z Potara Rings Simple
About: Everyday a masterpiece.
The rings which I have made to wear as Cosplay character Vegeto from Dragon Ball Z. These earrings are featured in the cartoon Dragon Ball Z and are called Potara earrings when Goky and Vegeta fuse to become one to defeat the villain!
List of all materials are:
  1. Spherical beads (colored) which are small, got them from a stationary shop.
  2. Spherical wooden beads with holes (20mm) which I got from a stationary shop.
  3. Pair of scissors (for small kids, take help from an adult)
  4. Green colored paint.
  5. Gloss varnish.
  6. Soldering wire (around 30cm should work).
  7. Two small washers (circular disc with a hole big enough to encircle the wire and small enough not to overgrow the large beads)
  8. Paint brush.
Step 1:
  1. Cut the soldering wire into two pieces of 12cm each.
  2. Fold one part of the cut piece in such a way so as to make a U-shape.
  3. Make another U-shape with the same piece and join it with the existing U-shape so as to make a clamp for the ear.
Step 2:
  1. Paint the 20mm beads with color green.
  2. Paint the gloss varnish after the green color is dried.
Step 3:
  1. Add the small beads to the other end opposite to the U-shape until the whole length is covered.
Step 4:
  1. Add the washer to this end.
  2. Now add the 20mm bead to this end and turn the soldering wire to make an L-shape in order to keep the bead in place.
Step 5:
Wear the Potara earrings and you are ready to fuse into a Vegeto and defeat your enemies!
