Drakan - Grey Dragon
Intro: Drakan - Grey Dragon
Remember Drakan: Order of the Flame? Well here is the grey dragon that you could play in multiplayer in paper :)! I have no idea if the multiplayer dragons even have names as I haven't found that anywhere? It was quite a hassle to get him out of the game and into Pepakura, but here it is! I will probably also make the rest of the dragons later on. You will need Pepakura in order to open the files. Just print, cut and glue him together. You can scale him as big as you want using Pepakura Designer. If you want to let him hang, just grab a needle and string and attach it at the right spot so he is in balance. If you are interrested in Drakan, be sure to check out Arokh's Lair!
>>> Download Drakan_GreyDragon_Papercraft here <<<
Download Pepakura Designer here: http://www.tamasoft.co.jp/pepakura-en/
STEP 1: Materials
Material list:
- Aleene's Tacky Glue (can be found at Pipoos)
- Cutting knife/scissors or Silhouette Cameo 2 (cutting machine)
- Cutting mat
- Black marker
- Tweezers (recommended)
- Paper
- Printer
- Thread (transparent or black)
- Needle
STEP 2: Print, Cut and Glue
- Print out the templates.
- Cut out the parts and use a black marker to hide white edges of the paper. Only use it at dark parts!
- Fold and glue the parts together.You should start with the most tiny/detailed part and that is the head. Work your way towards the tail and wings. Glue it flap by flap and ring by ring. You can also cut out and directly glue one part at a time so you don't accidentally lose a (tiny) part! You can fold using a ruler, a scissor or slightly go over it with your cutting knife.
__ _ __ = valley fold
__ __ __ = mountain fold
If you have a Silhouette Cameo, you can use that to cut the templates by making use of the Cameo plugin for Pepakura. Found here: http://www.tamasoft.co.jp/pepakura-en/download/vie...
If you need some more help here are some useful papercraft tutorials:
STEP 3: Use Thread and Needle to Hang the Model
First figure out where the balance point (neck) is so it hangs properly.
Put a needle and thread through that point to make him hang.
And you are done!
11 Comments
dragãozinho 1 year ago
Metalfist 1 year ago
Backyard Arsenal 8 years ago
this is awesome very creative and quite detailed! good work
Metalfist 8 years ago
Thank you :)!
hummingbird1 8 years ago
Voted for you:)
Thanks!
Wow! you did an awesome job!:)
Thx, glad you like it!
That_Jamie_S_Guy 8 years ago
Thanks :)!
