Draw Your Own Labyrinth.
30,606
45
14
Introduction: Draw Your Own Labyrinth.
About: I'm all about Making and Mental Health. Reach out if you need a chat - find me on Instagram, TikTok, Reddit, Tumblr and Twitter as @KitemanX.
A labyrinth is not a maze. Mazes are puzzles, designed to vex the mind, but labyrinths are contemplative designs, designed to focus the mind.
It is an ancient design, found carved into churches, temples and tombs around the world.
They are also easy and fun to draw, once you have the key.
Step 1: The Key
The key is the simple pattern around which the labyrinth is constructed. Most are based on crosses, and it is the order in which the points are connected that creates the form of the paths.
Step 2: A Simple Key
The simplest key is a single cross plus four points (see the first image). If you join the points in the order they are numbered, you will produce the simplest unicursal ("single path") labyrinth - follow the path with your eye or finger, and you get to the centre. To get back, you re-trace your steps.
Step 3: The Common Key...
Most labyrinths start with a key like the one in the first image below. Following the numbered points also produces a simple unicursal labyrinth.
Step 4: ... Made Less Common.
Using the same keys, but re-ordering the points, produces more interesting labyrinths.
This is also unicursal, but with a twist. Try it to find out why (don't join a line to the point marked "X").
Step 5: Some Keys to Try.
The same basic key can be given more than one layer. Keys are also not restricted to simple crosses.
Try starting with the keys in the images below, experimenting with the ordering to see what happens to the path.
Step 6: Like Minds.
It turns out (thanks, Adam), that there are people dedicated to labyrinths as art, mathematics and mysticism.
Some of their ideas are a bit "new age" for my taste (the "Energy Keepers" need ti get a better grip on reality, I think), but there is still lots of useful stuff on their site:
http://labyrinthsociety.org/
Be the First to Share
    • Game Design: Student Design Challenge
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    14 Comments
    andrea biffi
    andrea biffi
    9 years ago on Introduction
    that's interesting, I used to draw impressive labyrinths on squared sheets when I was at secondary school. Some of them filled a full double A4 sheet and my deskmate took a lot of time to solve them :-)
    the most complex labyrinths had secret passages and keys to find to open doors! LOL
    TimmyMiller
    TimmyMiller
    11 years ago on Introduction
    which are are you?
    hoggle, ludo, or jereth (the goblin king played by David Bowie)?
    geek27
    geek27
    15 years ago on Introduction
    Very Cool! I'll totally give this a try!
    da fox144112
    da fox144112
    16 years ago
    this instructable is great i do it in school everyday i get in trouble but oh well : - )
    stienman
    stienman
    16 years ago
    You may want to add a link to The Labyrinth Society so people have somewhere else to turn if this instructable piques their interest, as it did mine.
    For instance, the centralized design fungus amongus requested can be found on this page about classical concentric labyrinths .
    I'm hoping to build my own labyrinths and gardens, and this is a great starting instructable, thanks!
    -Adam
    Moving in southeast michigan? Buy my house: http://ubasics.com/house/
    Interested in electronics? Check out the projects at http://ubasics.com
    Building your own house? Check out http://ubasics.com/home/
    Kiteman
    Kiteman
    Reply 16 years ago
    Thanks, Adam. I've added it as the final step.
    fungus amungus
    fungus amungus
    16 years ago
    What about a technique for having the destination at the center? This seems to push it towards the bottom.
    Kiteman
    Kiteman
    Reply 16 years ago
    There are labyrinths with much more centralised designs, but that's what they are; designs. They take careful planning and laying out. This is by far the oldest form of the labyrinth, the one most likely to turn up on a stone-age tomb wall, because all you have to learn is the central key. After that, all it takes is a few strokes of the pen or scratches of the flint to produce a completed pattern.
    fungus amungus
    fungus amungus
    Reply 16 years ago
    Interesting. I've walked a few of the more designed ones. They're nice to meditate on and then have a good sit in the middle. Haven't researched the labyrinths though and I like geeking out on geometry so I'll check some of this out.
