Introduction: Drawing With the Graphic LCD Phidget
In this project, you will learn how to draw pixels, lines and rectangles using the Graphic LCD!
- Graphic LCD Phidget
- VINT Hub
Step 1: Basics - Size
Before you begin drawing with the Graphic LCD, it is important to understand a few things about the device. To start, the LCD is 64 x 128 pixels.
Step 2: Basics - Origin
When drawing, the origin is in the top left corner.
Step 3: Basics - Pixel
So, for example, if you wanted to draw a pixel right in the middle, it would have the following coordinates (64,32). The x coordinate is 64 (half of 128) and y coordinate is 32 (half of 64).
Step 4: Drawing Lines - Python
Now that you have a basic understanding of the layout, let’s start by drawing a straight line. Copy the code below into a new Python script.
#Add Phidgets Library from Phidget22.Phidget import * from Phidget22.Devices.LCD import * import time #Create lcd = LCD() #Open lcd.openWaitForAttachment(1000) #Use your Phidgets lcd.drawLine(0,32,128,32) #Divide screen in half lcd.flush()<br>
Step 5: Drawing Lines - Java
Code for Java is available below:
package graphiclcd;
//Add Phidgets Library
import com.phidget22.*;
public class GraphicLCD{
public static void main(String[] args) throws Exception{
//Create
LCD lcd = new LCD();
//Open
lcd.open(1000);
//Use your Phidgets
lcd.drawLine(0, 32, 128, 32); //Divide screen in half
lcd.flush();
}<br>Step 6: Drawing Lines - Code Review
When drawing lines with the Graphic LCD Phidget, you have to pass four values:
- x1: the x-coordinate of the first point
- y1: the y-coordinate of the first point
- x2: the x-coordinate of the second point
- y2: the y-coordinate of the second point
Step 7: Drawing Rectangles - Python
Now that you know how to draw a straight line, try drawing a rectangle. Copy the code below into a new Python script.
#Add Phidgets Library from Phidget22.Phidget import * from Phidget22.Devices.LCD import * import time #Create lcd = LCD() #Open lcd.openWaitForAttachment(1000) #Use your Phidgets lcd.drawRect(25,5,35,50,False,False) lcd.flush()<br>
Step 8: Drawing Rectangles - Java
package graphiclcd;
//Create
//Open
lcd.open(1000);
//Use your Phidgets
lcd.drawRect(25, 5, 35, 50, false, false);
lcd.flush();
}<br>Step 9: Drawing Rectangles - Code Review
When drawing rectangles with the Graphic LCD Phidget, you have to pass six values:
- x1: the x-coordinate of the top left corner of the rectangle
- y1: the y-coordinate of the top left corner of the rectangle
- x2: the x-coordinate of the bottom right corner of the rectangle
- x2: the y-coordinate of the bottom right corner of the rectangle
- Filled: set to true to fill in the rectangle, otherwise a single pixel oiutline
- Inverted: Set true to clear the region instead of drawing
Step 10: Drawing Pixels - Python
Next, learn how to draw individual pixels.Copy the code below into a new Python project.
#Add Phidgets Library from Phidget22.Phidget import * from Phidget22.Devices.LCD import * import time #Create lcd = LCD() #Open lcd.openWaitForAttachment(1000) #Use your Phidgets lcd.drawPixel(64,32,True) lcd.flush()
Step 11: Drawing Pixels - Java
package graphiclcd;
//Create
//Open
lcd.open(1000);
//Use your Phidgets
lcd.drawPixel(64, 32, LCDPixelState.ON);
lcd.flush();
Step 12: Drawing Pixels - Review
When drawing pixels with the Graphic LCD Phidget, you have to pass three values:
- x: the x-coordinate of the top left corner of the rectangle
- y: the y-coordinate of the top left corner of the rectangle
- Pixel State: set whether the pixel is filled in or not.
Step 13: Learn More
Learn more at phidgets.com/education
Are you a teacher? Sign up for a FREE kit here: phidgets.com/education/free
