Introduction: Drip Watering
About: Im just a guy who got a 3d printer and I would like to look for a job in designing on day.
This is brilliant design is for drip watering. This is for the people who want their plants to be happy, they want the healthy plants, and that's exactly what this is for. First place this into a pot or the area which needs water. Push it down into the ground, and then fill it up through the hole in the top. And it's as simple as that. I have added the files you need, if you don't want to build it.
You will need:
:Any 3d printer
:Filament
:A place to design it
Step 1:
This is what you'll need, you can design this on tinker cad.
Step 2:
Place the cone onto the sphere.
Step 3:
Merge it, you will find this button in the top right hand corner. The other pictures are for measuring.
Step 4:
What you are going to do now, is duplicate, you can find the button in the top left hand corner, and then turn one of them into a hold, this button should pop up when you click on the item, now down size the hole by two ml on the width hight and length. and merge it all together.
Step 5:
place the hole on the bottom, this hole is 20ml by 20ml. and merge it.
Step 6:
now get your last hole, this one is 1.5 ml centre it at the top, and merge.
Step 7:
now all you have to do is take it to a slicing app, slice it and print it, and then you won't have to worry about watering you plants. {until it runs out} then you just have to fill it up again.
