Introduction: Driveway Car Wash
Purpose:
As a part of our Senior Design Project, the client has identified the need for a driveway car wash. The car wash must be able to perform all operations needed for cleaning the car in a size restricted area of an average size driveway. The water supply needed for the wash must be compatible with a standard garden hose and spigot. The main function required of the apparatus is the application of a pre-wash cycle (water), wash cycle (soap), and a rinse cycle (water). Team Shine Driveway Carwash will help resolve the issue of a dirty vehicle and reduce time from using more conventional methods of cleaning a car, such as automatic car washes or “do it yourself” washes at home.
Step 1: Assemble Cabinet
1.) Open box containing cabinet.
2.) Carefully place cabinet components on floor for assembly.
3.) Obtain casters(D) QTY(4) and install to bottom panel (E). Insert sixteen M6 x 16 hex flange bolts (AA) through the casters and into the bottom of the base cabinet. Tighten securely.
4.) Lock rigid casters QTY(2) and place base cabinet on floor. Obtain side panels (A & B) and install to the bottom panel (E) with two M6 x 16 hex socket head cap screws (DD)(security screws) and six M6 x 16 hex socket head screws (AA).
5.) Align front top beam (I) to the side panels (A & B) and install six M6 x 16 hex socket head screws (AA). Insert the screws by hand. DO NOT tighten.
6.) Repeat same process for back top beam (J).
7.) Attach the back panel (F) to the back of the cabinet with six M6 x 16 hex socket head screws (AA). Insert screws by hand. DO NOT tighten.
8.) Attach the top back panel (K) to the back of the cabinet with eight M6 x 16 hex socket head screws (AA). *Insert the top edge of top back panel under the back top beam. Insert screws by hand. DO NOT tighten.
9.) Attach the wood top (C) to the cabinet top by inserting four M6 x 166 hex socket head screws (AA) through the predrilled holes underneath the top beams (I & J) to the wood top (C). Tighten securely.
10.) Install door (G) by inserting the pins from the hinges on the door into the slot of the bottom hinges at the front of side panel (A).
11.) Install door (L) by inserting the pins from the hinges on the door into the slot of the bottom hinges at the front of side panel (B).
12.) Close the doors to see if the doors can tough the magnet completely. If not, adjust the cabinet's top and side panels to make sure the shape of the cabinet is square and flush. Once doors catch magnets completely, tighten top beams' and back panels' screws.
Step 2: Disassemble Pressure Washer
1.) Unbox Greenworks 1800 PSI electric pressure washer.
2.) Disassemble soap reservoir by removing QTY(2) fasteners.
3.) Disassemble black support bar for pump/motor removing QTY(4) fasteners and QTY(4) nuts.
4.) Store unit for installation further in the build.
Step 3: Arduino Setup With Flowmeter & Solenoids
1.) Unbox Flow sensor
2.) Remove a minimum of 1" from the outer jacket (black) of the flow sensor.
3.) Remove a maximum on 1" from each wire sleeve QTY(3) of the flow sensor.
4.) Slide QTY(1) heat shrink butt connectors to each wire on the flow sensor.
5.) Take 3 additional wires that will be spliced to the flow sensor wires and twist their ends so the wires strains intertwine with each other.
6.) Slide the connector over the splice wire so that the soldering portion of the connector sits on the connected strains of the two wires.
6.) Using the heat gun, apply adequate heat to the connectors until they shrink and engage tightly. Set aside for later use.
7.) Remove Solenoid and 1/4 connectors from packaging.
8.) Install 1/4 connectors to Solenoid using thread sealant tape and a 9/16 wrench.
9.) Take 2 additional wires and repeat the splicing method used on the Flow sensor.
10.) After splicing, connector the opposite end of the spliced wires to 12V 2A Power Supply AC Adapter. * (Once installed inside the cabinet, there will be a total of 3 Solenoids connected to this adapter.)
11.) Using the Arduino breadboard, Display, Flow sensor and Solenoid, assemble the circuit illustrated in the diagram.
12.) Upload the Arduino code provide to test the system.
Step 4: Mount Pump/Motor
1.) To mount the pump/motor, the first thing you will need to do is to install the flow sensor to the pump using thread sealant tape and 1 3/8 wrench.
2.) Position the pump/motor to the left side bottom of the cabinet.
3.) Using marker of choice and tape, measure 14.5 inches from the front of cabinet door towards the back of the cabinet on the left side wall and trace the outline of the flow sensor connector center of that location.
4.) While the flow sensor is flush to the left side of the cabinet, mark the QTY (4) holes where the base of he pump/motor will be mounted.
5.) Remove pump/motor and proceed to make the cut on the cabinet at the noted position using a rotary drill and 1 3/8 hole cutter.
6.) Using a drill and 15/64 drill bit, cut QTY (4) holes on the base of the cabinet to mount the pump/motor.
7.) After drilling, install 1 3/8 grommet on fluid line entrance.
8.) Mount motor/pump using 1/4-20 X 4 IN Flat Philips with Nuts QTY (4).
9.) Repeat same drilling process on right side of the cabinet for high pressure hose entrance. This hole will be 2 inches from the back wall and 2 inches from the bottom plate. Install same grommet size as well once cut is complete.
10.) Install high pressure hose to pump by running hose through cabinet entrance.
11.) Using a 3/8 drill bit, cut a hole on the left side of the cabinet 6 inches from the edge of the door and 5 inches from the bottom of the base plate for the power entrance.
12.)Once cut, install 3/8 grommet to entrance and guide the power cord through the entrance.
13.) Install check valve onto flow sensor connector.
Step 5: Mount Hose/Wand Holsters
1.) Measure length of handle for brush, and lance/nozzle.
2.) Obtain strapped 2" OD PVC, and cut the lengths of the recorded QTY (2) measurements using a table saw.
3.) Obtain QTY (4) PVC clamps, and paint black along with the previous cut PVC tubing.* Allow to dry for couple of hours.
4.) Position one of the PVC clamps on the right outside cabinet wall at a 45 degree angle with the edge of the clamp 4 inches from the top of the cabinet and 5 inches from the left side of the side cabinet panel.
5.) Match drill the holes to the cabinet using the clamp and a 15/64 drill bit.
6.) At the same 45 degree angle, match drill again 12 inches down from the previous drill.
7.) Once drill is complete position lance PVC pipe at the 45 degree angle and install the new holster using QTY (2) PVC clamps and 1/4-20 X 1/2 IN Round Combo with Nuts QTY (4).
8.) Repeat the same process for the brush holster with the top PVC clamp positioned 6 inches below the top lance PVC clamps. * The distance between the two clamps on the brush holster is 12 inches.
9.) For the high pressure hose reel, position it on the right outside wall with the top edge 3 1/2 inches from the right side of the panel edge and 2 inches from the top of the cabinet.
10.) Match drill QTY (2) holes for the hose reel using 15/64 drill bit.
11.) Once drilled, install hose reel to cabinet using 1/4-20 X 1/2 IN Round Combo with Nuts QTY (2).
12.) Repeat same process for hose reel on the left outside cabinet wall.
Step 6: Solenoids Installed
1.)To mount the Solenoids to the cabinet, Use a 1/8 inch thick strap of aluminum sheet and cut it to a 4 in by 18 in sheet.
2.) Using a measuring tool, locate the center of the plate and marker that location using a marker.
3.) After marking the center of the place, measure 5 1/2 inches horizontal on both sides and mark those locations as well.
4.) Using a evenly cut of 1 in by 3 in tape, trace the back plate of the solenoid by sitting the solenoid flat on the tape.
5.) Using that trace of the solenoid, place it on each marked location of on plate centerline, and mark drill holes on the plate for the fasteners using a punch and hammer.
6.) Remove the tape, and drill QTY 6 holes for the solenoids on the sheet metal using a 6/32 drill bit.
7.) Mark QTY (2) additional drill location 2 inches from the edges of the plate horizontal and centered for the fasteners to mount to the cabinet.
8.) Cut holes on the aluminum sheet using a 15/64 drill bit.
9.) Using the black paint, coat the the aluminum sheet metal completely. *Allow a couple of hours for paint to dry.
10.) Once paint has dried, mount all all 3 solenoids to the aluminum sheet using Hillman #6-32 x 1/2-in Phillips-Drive Machine Screws QTY (6) for 6/32 holes.
11.) Cut QTY (2) pieces of clear tube 8 inches long and QTY (1) piece 5 inches long.
12.) Connect QTY (2) pieces of 8 inch tubes on the outside solenoids using aluminum clamps. * The side of the solenoids does not matter as long as they are on the same side.
13.) Connect the last piece of 5 inch tube to the middle solenoid on the same side.
14.) Connect the opposite sides of the clear tubes to the 1/4" Stainless Steel Cross Barb 4 Way Co2 Splitter using the aluminum hose clamps as illustrated in the picture.
15.) Cut a 20 inch piece of tube and connect it to the last entrance of the 1/4" Stainless Steel Cross Barb 4 Way Co2 Splitter.
16.) Cut 3 additional pieces of the tube all 15 inches long and install them to the opposite side of the solenoids using the aluminum clamps.
17.) Install the filters to the opposite end of the clear tubes QTY (3) for the liquids.
18.) Position the aluminum sheet on the back wall of the cabinet 6 inches from the top of the cabinet and 2 inches from the right side of the wall.
19.) Match drill QTY (2) holes from the aluminum sheet onto the back wall of the cabinet.
20.) Once drilled, install aluminum sheet with solenoids to cabinet using 1/4-20 X 1/2 IN Round Combo with Nuts QTY (2).
21.) Route tubing and wiring for solenoids using adhesive cord/tube clips and pictures as reference.
Step 7: Install Waterproof Electrical Box
1.) Locate the vertical centerline of the Electrical Box and mark QTY (1) locations 1 inch from the top of the electrical box.
2.) Using a drill press with 15/64 drill bit, cut the hole location out of the Electrical Box.
3.) Once drilled, Position Electrical Box on left inside wall of cabinet centered 6 inches from the top of the cabinet.
4.) Once aligned, match drill QTY (1) location from the Electrical box to the cabinet.
5.) Install Electrical Box to cabinet using 1/4-20 X 1/2 IN Round Combo with Nuts QTY (1).
Step 8: Controls Install
1.) On the outside left wall of the cabinet, apply 3 inch masking tape horizontally 4 inches from the top of the cabinet.
2.) Using a writing utensil, draw a 2 inch by 3 inch vertical rectangle centered 5 inches from the top of the cabinet and 3 inches from the back edge of the cabinet.
3.) Construct 4 drill cross locations horizontally parallel to the center of the rectangle and 4 inches apart from each other.
4.) Cut out rectangle outline using dremel tool and 15/16 inch cutting disk.
5.) Cut the 4 drill locations using a portable drill and 1 inch drill whole cutter attachment.
6.) Using the dremel and sanding attachment, remove any rough edges from cutting.
7.) Install Power switch by inserting switch into rectangle location until the locking clips of the switch engages and holds the switch in place.
8.) Install Water and Soap application buttons into the remaining QTY (4) drilled locations using 1 1/2 inch washers on both sides of the cabinet. Tighten nut on controls until crescent wrench until snug.
9.) Install connectors to Water and Soap buttons and route to electrical box.
10.) Install power surge and Arduino Board inside electrical box using double-sided Velcro.
11.) Install routed connectors to Arduino using diagram provided in Step 3 for buttons.
12.) Install power supply for Arduino and Solenoids.
Step 9: Wiring Installation
1.) Using the Wiring Diagram illustrated above, assemble the power circuit.
Step 10: Install Pump/Motor Cover
1.) Cover Safety Label using masking tape to prepare for paint.
2.) Apply two coats of paint to Pump/Motor Cover.
3.) Allow an hour to dry and install cover with supplied screws using Philips screwdriver.
Step 11: Install Extendable Tray
1.) Position Extendable Tray Mount inside cabinet 2 inches from the right side of the wall and 2 inches from the front entrance of the cabinet.
2.) Mark the location of the holes QTY (4) and drill holes using portable drill and 15/64 drill bit.
3.) After holes are drilled, installed mount using portable drill and Philips bit.
4.) Install extendable drawer to mount once installed.
5.) Add Soap and Degreaser applications to tray.
6.) Insert clear tube with filter that was install to solenoids in Step 5 into desired liquid application.
