Introduction: Drone Navigation - Rapidly-Exploring Random Tree
This project implements a navigation algorithm known as a Rapidly-Exploring Random Tree (RRT) to navigate through an obstacle course
Crazyflie 2.1 Drone
Jupyter Notebook
Step 1: Overview
This project takes the theory of the RRT algorithm and implements it into a crazyflie drone to navigate a known obstacle course. While researching, I stumbled upon this paper by Steven M. Lavelle. He outlines the benefit of an RRT to be robust across many scenarios - holonomic & non-holonomic constraints and higher DoF systems. This allowed me to use the RRT to path-plan for a 6 DoF non-holonomic drone.
This story outlines the code for RRT creation, configuration space planning, and hardware implementation. A video at the end displays the drone's performance.
Step 2: RRT Algorithm Setup and Helper Functions
These blocks are for the setup and helper functions of the main RRT algorithm. The blocks follow the photo sequence:
- Setup
- Configuration checking
- Edge checking
- Random configuration sampling
- Path creation
Step 3: Main RRT Algorithm
The algorithm follows the sudo-code developed by Steven LaVelle in his paper.
- Main RRT algorithm
- Path creation through back tracking
Step 4: Define Configuration Space
This creates a configuration space for the RRT navigation. The algorithm "knows" how the course will look by receiving measurements of the location and size of each obstacle in advance. The drone has a set boundary that determines the universal location. Although the RRT depicts the drone as a point, the obstacles are "inflated" to compensate for the drones volume.
Step 5: Plot the Trajectory
After plotting the trajectory, the path should look something like the above. Sometimes a path isn't found due to the RRT's random nature. Just retry the block until a path is found.
Step 6: Implement Into the Hardware
A file for the entire code file is provided below
Step 7: Results
The output should look similar to this:
Trajectory Setpoints
The final result video is embedded above.
