Introduction: Drum Making: Spraying a Sunburst Finish
An easy drum building method is to achieve a sunburst finish with aerosol cans for a simple DIY Drum Making project.
Step 1: Prepping the Shell
Sand the drum shell with 320 grit paper, and then wipe it to remove the dust. Wiping the drum with a shop towel, and then a Tak cloth is the preferred way to properly remove all the dust.
Step 2: Prepping the Inner Shell
Prep the inside of the shell to protect it from overspay. I do this with tape and tin foil. Newspaper works also.
Step 3: Spray the Base Coat
Apply 4 nice sanding sealer coats and let each coat dry thoroughly. Let the last coat dry overnight. You'll see in the picture how long I wait for each coat.
Step 4: Sand the Drum Shell Again
In the morning lightly sand the drum shell with #320 paper for a nice and smooth surface. Drum making is all about prepping: the finished product is only as good as the start... so make that baby nice and smooth.
Step 5: Apply the Dark Edges
Apply the dark colored (usually brown) Sunbursting Aerosol Can to the edges of the drum shell. Make this as dark as you wish (many coats will get it black) and as large as you want. Lay the first few coats on very lightly and let it dry thouroughly, then following coats can be laid on thicker.
Step 6: The Yellow Zone
Apply the amber/yellow Subursting Aerosol Can to the rest of the drum. The yellow color will not effect the dark edges, so overlap the yellow into the dark edges to make sure you're not missing any spots. You'll see in the picture that my dark edges are very straight and stripe like... I simple did this in the Guerrilla Drum Making DVD to show that you can also stripe drums. Your edges will look a little more blended and less linear.
Step 7: Apply Lacquer
Hit the entire drum with a tleast 2 coats of gloss lacquer aerosol. I know... when youre making drums it's tough to be patient... but if your not in a hurry, I would do 4 coats or more. This locks in the amber zone and protects it. Any overspray from our next step can be carefully smoothed off with #0000 steel wool.
Step 8: Apply the Transition Zone
Add the transitional red zone. This is achieved by applying the brown Sunbursting Aerosol right where the black edge meets the yellow/amber zone. This zone can be as big or as small as you want your burst or fade to extend. I went through the most drastic example in my Guerrilla Drum Making DVD to show how big of a burst you could actually do.
