Introduction: Drunkards Path Quilting Template Tutorial
In this instructable, you will learn how to cut and stitch the drunkards path for blocks on your next quilt.
Supplies Needed:
2-4 Fabric colors
Rotary wheel
Cutting mat
Sewing Machine
3.5" Drunkards Path Template
or
7" Drunkards Path Template
Step 1: Cut the Fabric
Use the acrylic templates to cut the fabric with your rotary wheel (I used orange templates in this tutorial for higher contrast in the pictures). The straight edges are easy, the curves are tricky. If you have trouble cutting the curves with the rotatry wheel you can trace the curve with a pen and then cut it with the rotary wheel or sharp scissors. Be sure to mark the holes for the 1/4" seam allowance with a pen.
Step 2: Pin the Fabric Together
Find the center of the fabric and pin it. Now line up the corners and put another pin right at the corner. The fabric will start to scrunch, don't worry though, this is normal. Now put a pin in between the two pin you just added. If the fabric is bunching a little, this is fine, just make sure the bunches are some what even on either side of the middle pin. Now do the same for the other half. You should have 6 pins for a small 3.5" block.
Step 3: Sew the Pieces Together
Line up the 1/4" seam allowance on your sewing machine and stitch it up. Be sure to keep the fabric together with a stick or pin between the pins that are in place. Go slow for the first few, you will get faster with practice. For curved pieces, try to get a nice arc, slowly turning the piece after each stitch. I put my machine on the slowest setting for this.
Step 4: Iron the Block Flat
Iron the block flat by placing the seam to either side and then ironing. Some people also split the seam part so the lump is even.
Step 5: Sew the Blocks Together to Form Larger Blocks
Once you have a bunch of blocks made, turn the blocks and mix the colors and try out some different pattern and variations.
Step 6: Summary
Summary: The centers of my blocks did not line up very well because I did not pin the squares together first. In retrospect, I should have pinned them, I though I could get away without any. The templates used in this tutorial and more can be found on our blog, or on my Etsy store. Check us out on Facebook, Twitter, and Pinterest.
