Introduction: Drywall Sanding Dust Collector/Separator
Drywall sanding produces lots of dust no matter how dust free your joint compound claims to be, Drywall dust will quickly clog your shop vac filter and shorten the life of your vacuum.
There is a wide selection of drywall dust separators on the market from $50 or so on up to several hundred dollars for a nice Festool extractor. Being a DIY homeowner, taping drywall is not a full time job and doesn't warrant spending the money, so I decided to make my own with about $20 at the local hardware store, This price can be more or less depending on how you make it and what items you might have lying around, I could have used an old bucket but opted to buy a new one for this project, about $5 for bucket and lid at Lowes.
Step 1: Shopping List
There are numerous ways to configure this with PVC pipe and hoses. I chose to do this with a combination of threaded and slip PVC fittings for my shop vac that has a 1 1/4" hose.
1 - Bucket and Lid
1 - 1" schedule 40 PVC pipe, cut in several sections: 1 x 12" and 4 x 1 1/2"
4 - 1" PVC female slip to male threaded
1 - 1" PVC threaded coupling
1 - 1" PVC slip to threaded coupling
2 - 1" PVC slip 90 degree elbows
1 - 1" PVC female slip to male threader 90 degree elbow
PVC primer and glue
All purpose PVC glue
Tools
Hacksaw to cut PVC pipe
1 1/8" spade bit or hole saw (I used a 1" spade bit and widened the hole with a box cutter)
Step 2: Prep and Assembly
Drill the holes in your bucket, I'm not certain that placement is important but I put the sander hole in the center and the vacuum hole near the rim. Hole should be slightly undersized so PVC thread ends can screw in tightly.
Cut the PVC pieces, 1 x 12" piece and 4 x 1 1/2" pieces. I used a hacksaw, but a sawzall might make faster work of this. Sand the ends to remove any burrs.
Dry fit all of your PVC pipe and fittings to ensure you have everything in order. I failed to take a picture of the fittings laid out, so please see the sketch.
PVC primer all of your slip ends. WEAR GLOVES, PVC primer and glue is nasty stuff and does not come off easily, so unless you want sticky purple hands, wear gloves.
PVC glue all of your slip ends and push together your fittings, If you never done this before, you may want to glue them one by one, PVC glue has very little working time, precious few seconds.
Use the general purpose glue on the PVC threads that will go through the bucket lid, screw the threads through the lid and then screw your threaded ends together, till the lid is firmly between the two ends.
Step 3: Done
Add water to your bucket so that the end of the center tail pipe is under water.
Attached completed lid assembly.
Attach sander hose to intake pipe and vacuum hose to exhaust pipe.
You might need a hose clamp if your vacuum hose does not fit snugly, my sander hose fit very tightly, but the vacuum hose was a bit loose.
Happy sanding!
I Could Make That Contest
72 Comments
Question 6 months ago
I like the idea and am in need of a water type filter for my metal grinder dust. Does anyone know whether this would work for metal or will it cause the combustion I am trying to avoid??
2 years ago
This did not really work out all that well......First off, my build is exactly as the directions sated. First use I started drawing water into my vacuum from the bucket. I figured it was due to the water bubbling as the air was sucked from my sander. To make a long story short, it destroyed my vacuum bag lol. Next I tried using less water in the bucket, this prevented water from being drawn into the vacuum, but less water meant less for the sucked up dust to travel through. Use your shop vac, and clean the filter every hour or so. Works better than this.
Reply 1 year ago
I'm having the same issue. I didn't realize it was drawing water into my vacuum until I went to empty the bucket. It was full of wet drywall dust and wood shavings from the afternoon.
9 years ago on Introduction
Do I understand correctly that negative air pressure (suction) is created in the tube that is attached to the sander THROUGH the water by creating a suction above the water? In order for that to happen, something must be driving the suction and pulling the air through the dust hose perhaps by sucking the gas molecules out of the water, which as far as I know, can only be done by evaporation, cavitation (bubbling), or electrolysis. Obviously electrolysis isn't happening, it won't work via evaporation until all of the water is evaporated, and you have already said not to let it bubble. Perhaps I am missing something and I will have to try this to see it work. I can see this working if both pipes in the bucket are above the water and at opposite sides of the lid but otherwise I don't buy it. Not to worry though as I don't mind eating humble pie when proven wrong.
Reply 3 years ago
Works just like a water bong, but instead of cleaning smoke-filled air by bubbling it through water, it's cleaning dust-filled air the same way. Sure, some dust gets through just like smoke gets through a bong, but the turbulence would be pretty fierce with all that air being pulled up through the water, creating a lot of splashing, which would additionally help to grab dust. Pretty neat idea, I think.
When the pressure drops above the water, the water level rises. It rises because the pressure on the intake pipe, the one below the surface, is greater then the inside pressure. A bubble of air will come chugging up into the water from the input pipe.
For additional reference material, find a pothead with a water pipe. Same thing.
Well, I finally got to this project and created a test separator, but on a micro level using a clear glass jar instead of a 5 gallon bucket. I was wrong and you were, of course, right. It not only worked, it worked quite well and easily. So, if you could see me, I would be eating humble pie :-). I thank you for the comment and the good and ultimately 'instructive' instructable. Perhaps if I had been a pothead, I might never have given this a second thought. Hmm, now that I know how a 'waterpipe' works, and it seems I effectively have one . . . .
I look forward to future 'ibls.
4 years ago
Thanks for the idea. I made it. And used it for drywall. Problem is the plastic bucket collapsed after vacuum had run for 20 s. Ferry decreased section. Any ideas? Stronger bucket?
Reply 4 years ago
I use 1 inch wide metal strip and bond it with bucket using 3M double tape. It works very well..!!
Reply 4 years ago
I used a drywall mud bucket, which was pretty sturdy.
Question 5 years ago on Step 2
Great project and instructions! I was able to put together but had a question one the shop vac. Do you expect water from the dust/water bucket to find its way into the shop vac? If so would you recommend removing the filter?
6 years ago
Will this work for airbrush paint extractor?
7 years ago
Going to make this as filters are a pain to bang out the dust and blow out plus too expensive to keep replacing. I am thinking of adding half inch holes in the underwater part of the intake pipe to aid in water contact with the dust.
7 years ago
For the connection through the lid, get a couple of close threaded nipples, then go to the electrical dept. and pick up some lock nuts and reducing washers.
8 years ago on Introduction
I worked for 50 yrs in Jersey. lived in Piscataway mostly. bought one of these things from hd when they opened the p,burg store. could,nt believe the efficiency of it. got parted from it along the way. now flipping houses in Kentucky and doing drywall. let you know how it works when built. thanks a bunch for this, great idea.
9 years ago on Step 2
naprawde fajne
Because you're already at a disadvantage with the dust collection using a shop vac, I would strongly advice you take the two top hard 90 degree elbows off the top and just plug the hose vertically. All those 90's do is steal power.
Other than that this is an awesome simple, cheap fix to a problem! Thanks!
9 years ago on Step 3
Thanks a lot this is brilliant...
I was looking at my old shop vac and a bucket and was wondering if it would be possible to do something like this as a dust separator for my workshop and also for plastering.... as i am fitting plasterboard ( aussie drywall ;) ) and it is amazing how you get ten times more dust back when you sand the jointing compound.
I would never have thought of putting water in the bottom to stop the dust but i can see ti will work brilliantly on plaster dust..
Could you tell me how long it takes before the water stops filtering the air or does it just keep going as the dried compound doesnt mix with water?
Also could this set up be used to filter wood dust from a router and saw etc..
Cheers
Reply 9 years ago on Step 3
The idea to use it for sawdust/wood chips is not bad, just be careful as air with a sufficient amount of fine sawdust will make a VERY combustionable mix.
If you add the static electricity from a plastic bucket where a vortex of air spins the sawdust in high speed around the sides you have a potentially dangerous contraption.
This is why commercial separators are made of metal not plastic.
One way to mitigate the risk of self ignition would be to add a grounding strip/cable and connect it to something grounded. For example a waterpipe or radiator(if you have waterfilled radiators and not electrical ones)
(Sorry if the technical terms are not correct, English is not my first language.. :-) I hope you get the gist of my post)
Thanks a lot for the explanation..... makes a lot of sense.. I thought the water would have just been to trap the plaster particles.. but i never thought about the potential for fireworks galore if I use it for wood.... Thanks for the warning and advice...
I guess the same risk exists with the plastic cyclonic separators too then....
