Introduction: Dual 3D OctoPrint Server With Powerswitch
It is a little bit dangerous to let a 3D printer run unattended. 220 degree at the Hotend, a heated printbed, liquid plastic and in my case cheap electrical parts from china... So I wanted to monitor the print process from everywhere and the possibility to shutdown my both printers ... here is my solution ...
If you have only one printer you can use the second plug socket for lighting as example. This construction is also usable as an IPswitch without octoprint, if you want to switch more plugs, you just need more relay and plug sockets ...
If you do not have any experience with electricity, do not do this instructable, a little mistake can be really dangerous ... If you do this instructable, you do it on your own risk !
Step 1: Requirements:
materials:
- Raspberry Pi 2||3
- 4 channel relay modul
- 2 * plug sockets
- rubber connector socket with switch and fuseholder
- raspi cam
- raspi cam cable 1m
- 12V 2.1A switching power supply
- 5V step down converter with micro usb plug
- fan with temperature sensor
- 4A fuse (fast-acting)
- PLA
- cable (NYM-J 3x1.5mm²) 1m
- cable shoes
- a lot of screws
know how:
- Fusion 360 or every other 3D modeling software
- 3D printing
- how to setup a raspberry
- linux
- basics of bash scripting
- high voltage electricity
Step 2: How I Made the Case:
I used Fusion 360 to design the case. To got an idea how big the case has to be, I downloaded all 3D models which I found:
https://grabcad.com/library/raspberry-pi-3-1
https://grabcad.com/library/pc-fan-92mm-arctic-f9-...
https://grabcad.com/library/4-channel-relay-board-...
I created the other models ( rubber connector socket, plug sockets, step down converter, power supply ) very simple by hand. After that I arranged the models several times until I had a compact and accessible inner life of the case. Now I was able to design the case around the parts, there is a distance of 8 mm between the case and the parts for air circulation. I printed the case parts with a wall thickness of 1.2 mm and an infill of 20%(cura settings) ... The side and the top/bottom parts are 3mm thick and they are a little bit flexible, so 4 or 5 mm are a better choise ...
Step 3: Electricity:
High voltage:
I switching both pole, in case of plugs and cable you can never know, which pole has power and which one not, so it is just saver ... I used copper cable with a 1.5 mm2 cross section, not needed in this case, but also saver :-) and the connection to the plug sockets is better ... It is very important to connect through the PE conductor ... I used a 12V power supply, so I have energy for the fan and I can use one of the step down converter with micro usb plug, so it is simple to power the raspberry ...
hints from other users:from Tinkering On Steroids:
- protect the 220v connectors with shrink tubes or isolation tubes ...
from Chris Rowe :
- seperate the high voltage area from the low voltage area, as example with a middle strut ...
- protect the whole high voltage wires with shrink tubes or isolation tubes ...
I got some hints from other users which has fear that my construction will burn or the relays are not strong enough, so I have to say the following one:
- my first printer has a powersupply with 400W
- my second printer has a powersupply with 250W
- so the max. used power will be 650W
- the max. power of a flexible extension cable with 1.5 mm2 cross section is 3200W
- so my plug/socket construction with non flexible cables should also handle 3200W
- every relay on the relay board can theoretical handle 2500W ( I do not trust them )
- my 4A fuse will acting by ca. 1000W
- so I think there is enough reserve to the upper limit
- and I'm not going to switch my electric kettle with this construction :-)
please do not hesitate to contact me, should you have some hints or suggestions ...
Low voltage:
I power the relay module with 5V from the raspberry, I used 4 free gpio pins from the raspberry, which do not have other functions like I2C, Serial and so on, to prevent serveral effects, like relay flap during the boot process ...
Step 4: Installing and Configuration of 2 Octoprint Instances:
https://github.com/foosel/OctoPrint/wiki/Setup-on-...
- start with Basic setup
- Updating & Switching Branches is not really needed
- do Webcam if you want to use one
- do Automatic start up if you want that the server start up during boot process
- I describe System commands in the next step, so you can skip it here
- Make everything accessible on port 80 is usefull, if you want to access your print servers via standart http port, I had an apache already running, so I did another solution, see next steps
to install a second instance, repeat the tutorial with some little changes:- Basic setup
cd ~ git clone --depth 1 https://github.com/foosel/OctoPrint.git OctoPrint2 cd OctoPrint2 virtualenv venv ./venv/bin/pip install pip --upgrade ./venv/bin/python setup.py install mkdir ~/.octoprint2
- Webcam
I used one picam for both printer, so nothing to do here
- Automatic start
- rename your ~/OctoPrint2/scripts/octoprint.default to ~/OctoPrint2/scripts/octoprint2.default
- change the content of ~/OctoPrint2/scripts/octoprint2.default to:
# Configuration for /etc/init.d/octoprint2 # The init.d script will only run if this variable non-empty. OCTOPRINT_USER=pi # base directory to use BASEDIR=/home/pi/.octoprint2 # configuration file to use CONFIGFILE=/home/pi/.octoprint2/config.yaml # On what port to run daemon, default is 5000 PORT=5001 # Path to the OctoPrint executable, you need to set this to match your installation! DAEMON=~/OctoPrint2/venv/bin/octoprint # What arguments to pass to octoprint, usually no need to touch this DAEMON_ARGS="--port=$PORT --config=$CONFIGFILE --basedir=$BASEDIR" # Umask of files octoprint generates, Change this to 000 if running octoprint as its own, separate user UMASK=022 # Process priority, 0 here will result in a priority 20 process. # -2 ensures Octoprint has a slight priority over user processes. NICELEVEL=-2 # Should we run at startup? START=yes
- rename ~/OctoPrint2/scripts/octoprint.ini to ~/OctoPrint2/scripts/octoprint2.ini
- change the "INIT INFO" part of ~/OctoPrint2/scripts/octoprint2.ini to:
### BEGIN INIT INFO # Provides: octoprint2 # Required-Start: $local_fs networking # Required-Stop: # Should-Start: # Should-Stop: # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: OctoPrint2 MyPrinterName daemon # Description: Starts the OctoPrint daemon with the user specified in # /etc/default/octoprint2. ### END INIT INFO
- execute the given commands with octoprint2
sudo cp ~/OctoPrint2/scripts/octoprint2.init /etc/init.d/octoprint2 sudo chmod +x /etc/init.d/octoprint2 sudo cp ~/OctoPrint2/scripts/octoprint2.default /etc/default/octoprint2 sudo update-rc.d octoprint2 defaultsdo start / stop with:
sudo service octoprint2 {start|stop|restart}
after you start both daemons, you should able to access both print servers via:
- please go on both through the initial configuration
- it is helpfull if you use differnet colors for every print server
- configure one printer per print server
Step 5: Turn On, Turn Off Your Printers ...
I created 3 scripts in ~/.octoprint/scripts :
enable_socket1.sh:
#!/bin/bash # pins of socket 1 gpio -g mode 18 out gpio -g mode 27 out gpio -g write 18 0 gpio -g write 27 0
disable_socket1.sh:
#!/bin/bash # pins of socket 1 gpio -g mode 18 out gpio -g mode 27 out gpio -g write 18 1 gpio -g write 27 1
disable_socket1_after_time.sh:
#!/bin/bash
if [[ $(date +%u) -gt 5 ]]
then
# at the weekend
if [[ $(date +%-H) -ge 7 ]] && [[ $(date +%-H) -le 21 ]]
then
# do nothing during 7:00 til 21:59 o^clock
exit 0
fi
else
# during the week
if [[ $(date +%-H) -ge 16 ]] && [[ $(date +%-H) -le 21 ]]
then
# do nothing during 16:00 til 21:59 o^clock
exit 0
fi
fi
# wait 10 minutes, so that the printer can cooldown ...
sleep 600
# pins of socket 1
gpio -g mode 18 out
gpio -g mode 27 out
gpio -g write 18 1
gpio -g write 27 1
- i added execution rights to this files "chmod 750 *.sh"
- after that I added the following lines to ~/.octoprint/config.yaml :
system:
actions:
- action: enable_socket1
command: ~/.octoprint/scripts/enable_socket1.sh
- action: disable_socket1
command: ~/.octoprint/scripts/disable_socket1.sh
confirm: You are about to disable printer AnetA8!
events:
enabled: True
subscriptions:
- event: PrintDone
command: ~/.octoprint/scripts/disable_socket1_after_time.sh
type: systemThe first block "system" is to add 2 commands(enable/disable socket1) to the webgui, the second block "events" starts the script disable_socket1_after_time.sh after every finished print, but the script itself disable the printer only during the night and my worktime ...
I did the same equivalent for ~/.octoprint2 with the pins of plug socket 2 and restarted both octoprint daemons:
service octoprint restart service octoprint2 restart
or you can use a plugin:
I got the information from "vitormhenrique" that he created a plugin for octoprint to switch gpio pins via octoprint web interface ...
https://www.instructables.com/member/vitormhenriqu...
https://github.com/vitormhenrique/OctoPrint-Enclos...
I didn't test it, yet ...
Step 6: One Website for Both Daemons
this step depends on your own network configuration, so I can only show my way:
I added 2 additional IP adresses to my raspberry pi network interface
http://www.raspberry-projects.com/pi/pi-operating-...
I added 2 additional dns aliases to my router config which points to the additional ip addresses:
aneta8.fritz.box
daycom.fritz.box
I added 2 virtualhost configurations to my existing apache config:
<VirtualHost aneta8.fritz.box:80>
ServerAdmin webmaster@localhost
ServerName aneta8.fritz.box
ErrorLog ${APACHE_LOG_DIR}/aneta8_error.log
CustomLog ${APACHE_LOG_DIR}/aneta8_access.log combined
ProxyPreserveHost On
ProxyRequests On
ProxyPass /video http://127.0.0.1:8080/
ProxyPassReverse /video http://127.0.0.1:8080/
ProxyPass / http://127.0.0.1:5000/
ProxyPassReverse / http://127.0.0.1:5000/
</VirtualHost>
<VirtualHost daycom.fritz.box:80>
ServerName daycom.fritz.box
ErrorLog ${APACHE_LOG_DIR}/daycom_error.log
CustomLog ${APACHE_LOG_DIR}/daycom_access.log combined
ProxyRequests On
ProxyPass / http://127.0.0.1:5001/
ProxyPassReverse / http://127.0.0.1:5001/
</VirtualHost>
so I am able to access my both printer directly ...
Step 7: At Last:
Maybe I am going to add some pushbutton to the box, to switch the plug socket directly on the printer station, a status display, some sensors which monitor the temperature around the printers or the power consumption is also possible.
If you like this tutorial, please vote for me, thanks ...
