Introduction: Duck Tape Bow!
What you will meed to make this adorable duck tape bow is:
1 pattern or colored roll of duck tape
An exacto-knife
A ruler
A cutting mat
Let's get started!
An exacto-knife
A ruler
A cutting mat
Let's get started!
Step 1: Step 1
First cut a strip that is 6 inches long
Step 2: Step 2
Then also cut a 7 inch strip of duck tape
Step 3: Step 3
Then you will cut 2 little strips of duck tape of your 7 inch piece. As demonstrated in the picture
Step 4: Step 4
You then take your 6 inch strip and face it sticky side up
Step 5: Step 5
Then you take your 7 inch strip of tape and lay it on top of the 6 inch one. MAKE SURE there is sticky on both sides of it.
Step 6: Step 6
Then fold one of the sticky edges over
Step 7: Step 7
Then fold the other side over. Now you have folded both sides of sticky over
Step 8: Step 8
When you flip it over there should be an ich of sticky. DO NOT cut it off
Step 9: Step 9
With the inch of sticky your cut the some pieces of to make it form a triangle
Step 10: Step 10
Next your going to connect the pieces together by folding them in
Step 11: Step 11
It should connect like this with the sticky triangle holding the other part on the bow
Step 12: Step 12
Now your gonna make sure that your bow is even, there should be about an ich and a half on each side
Step 13: Step 13
Then take ONE of the small strips of tape you cut earlier and wrap it around the middle of the bow. That's why we measured to make sure each side was even.
Step 14: Step 14
Wrap the piece of tape fully around the center
Step 15: Step 15
Then you may form the shape of your bow however you would like
Step 16: Step 16
Then still holding your bow so it keeps it formation then you can take the other piece of tape you cut and wrap it around the center at the same place we did list time
Step 17: Step 17
Once you have wrapped it fully you have your bow!
Step 18: Step 18
This is optional. You can puff the ends of your bow to make it look like this. But you don't not have too
Step 19: Step 19
That's it! Good job! Now you have just made your very own bow! You can have do much fun with these by using different colors and patterns! Hope you enjoy this tutorial and your bow !
