Introduction: Duck Tape Teacup
In this instructables I will show you how to make a teacup out of nothing but Duck Tape that everyone will love
Step 1: Supplies
You barely need any supplies for this instructable.
Duck Tape(two different colors if you want a design)
Your hands
Water
Your hands
Water
Step 2: The Bottom
Lay out some duck tape sticky side up in a circular disign, then lay more duck tape sticky side down over it so you can't see the sticky side of either of the layers anymore. Cut it into a circle for the bottom.
Step 3: The Sides
To make the sides of the teacup lay out one strip of duck tape sticky side up. Then lay another piece of duck tape (the same size) on top of it sticky side down. Then curl it around the bottom of the teacup and tape there, with Duck Tape, obviousely. You can keep building up the sides, but I made mine kind of small.
(before you cut the strip of Duck Tape you might want to measure the bottom and make the strip the same size)
Step 4: Handle
To add the handle roll up a bit of Duck Tape and tape it on.
Step 5: Decorate
Once you have finished making the basic teacup you can make a design. I chose a smile.
Step 6: The Sauser
You can also make a sauser if you want to. You can make it the same way as you made the base of the teacup, just a little bigger.
Step 7: Water
The final step: drink out of your new teacup!
(Please vote on this instructable it is for the duck tape contest, thanx!)
