Introduction: DuckTape Airsoft Pistol Leg Strap
Tired of putting your pistol in your pocket and then wacking your hand against it while playing airsoft? Well don't worry because I've got you covered!
-DuckTape
-Scissors or/ CraftKnife
-Lanyard
-Carabiner
Step 1: Making the Front
Start by taking strips and forming the front, Make the strips shorter as you move on we want to make a cone shape.
Step 2: Over Lay the Tape
Layer you're tape on both sides
Step 3: Wrap You're Pistol
Warp the pistol all the way around with the short end pointing to the trigger.
Step 4: Snip the End
Snip the end of the holster at a slant then cover with more tape.
Step 5: Add a Strip on Both Sides
Add two strips of tape on ether sides of the holster.
Step 6: Tape Together the Two Strips and Add a Trigger Strap
Tape together the two strips form the top and add a trigger strap it should lay over it. (Make sure its not to tight)
Step 7: Trim the Sides (It Just Makes It Look Nicer)
I made mine round. (Optional)
Step 8: Make Leg Strap
Make a strip (depending on how tall you are) this will be you're strap leading to a belt, Then fold it in half, loop a piece of tape this will hook on to you're belt.
Step 9: Attach You're Starp to the Holster
Tape you're strap to the holster with the loop facing away form the gun.
Step 10: Take a Lanyard to Hald the Gun on You're Leg
I doesn't really matter how you do it just make sure it holds the holster to your leg **Note you don't need to attach it to the holster it can just rest on it**
Step 11: And You're Done!
Feel free to tinker this it needs some work still but it dose the job.
