Introduction: Duct Tape IPod Touch Slip Case for Dirty Conditions
Work or play in a dirty environment? I do, and I like to listen to my iPod while I'm at it. I decided to make this and share it with the world.
What you will need:
1 Clear Plastic Freezer Bag
Duct Tape
Clear Packaging Tape
X-Acto Knife or Box Cutter
What you will need:
Duct Tape
Step 1: Cut the Freezer Bag to Size
The purpose of the bag is to protect from water and dust. It makes a pretty decent barrier. It also makes it easy to remove your iPod.
Place your iPod into the back at the bottom corner making sure you use the back side of the bag so the label isn't blocking the screen. Make sure it's in there nice and snuggly with the edges of the bag!
Proceed to cut around the iPod. Make sure you leave about 1.5 inches of slack on the vertical side and cut just about flush to the top of the iPod horizontally.
Next, tape the vertical edge of the back to the back of the iPod. Make sure it's not too tight or else you won't be able to remove your precious easily.
Step 2: Reinforce the Touch Screen
Cut out a piece of clear packaging tape about the length of the touch screen (Most packaging tapes are perfect width already). Stick it on bag over the screen while trying to keep bubbles to a minimum.
Side note:
Don't fret if you have a bunch of bubbles! A good technique for eliminating them is to take your X-Acto and poke the bubbles from the inside of the case, just enough to let the air out. Once you've done that, just squish the bubble and it will be almost perfect.
Side note:
Step 3: Bust Out the Duct Tape!
With your iPod still in the bag, start putting tape carefully around the screen. I started with putting the horizontal pieces first.
When you put the top horizontal piece on, make sure you have quite a bit hanging off the edge to make a flap so you can wrap it around the back side. Put tape on both sides of this flap.
Step 4: The Flap Strap
Fold over a piece of duct tape and cut out two identical pieces measuring about 1/2" by 1.5". Lay them flat on a clean surface. Take another piece of duct take and cut it in half lengthwise. Stick it to both sides of the two pieces as shown.
Pull it off the surface and stick it to the back of the casing near the top so the two double sided pieces are horizontal to the flap.
Take another strip of duct tape about 8" long and cut out a long strip about 1/2". Fold it over so that it is sticking to the flap on both sides.
Do a quick test to see if the strap is long enough to hold. If not, make adjustments accordingly.
Step 5: The Headphone Jack Hole
Pull your iPod out of the case and lay it flat on its face so that both the bottoms of the case and iPod are touching. Take a marker or make a mental note on where the hole should be cut out. Use an X-Acto knife or some other fancy tool to gouge a hole.
Congratulations! You have yourself a fairly rugged iPod case! I haven't drop tested it yet, but I do believe that is where this case is lacking. Have fun!
