Introduction: Duct Tape Belt
How to make a cheap belt with things you find around the house. I made this belt one day when my old belt was starting to wear out, it is easy and doesn't take much to make.
Step 1: Materials, and Tools.
For this instructable you will need:
1 roll of duct tape
1 Pair of scissors
1 pen
1 ruler
2 key chain rings
1 roll of duct tape
1 Pair of scissors
1 pen
1 ruler
2 key chain rings
Step 2: Measure Tape.
Measure the tape out to fit your waist. You will need to double the amount. Fold over its all but the last 1 inch.
Step 3: Choose Thickness
get you ruler and measure how thick you want your belt all the way down. i made mine 3CM but you can make it bigger or smaller.
Step 4: Cut
Cut the Tape along the line you just made.
Step 5: Fitting the Rings
If your belt is as thick as mine you will need to cut the end so that the rings will fit.
Step 6: Puting Rings On
Slide the key chain rings on the end and fold it over.
Step 7: YOU'RE DONE
You now have a belt. to put it on you need to put the end through both rings then bring it around the top ring and through the bottom.
