Duct Tape Canoe
Intro: Duct Tape Canoe
I made this boat to have fun and see if we could do a canoe with duct
tape and pvc tubes. The boat is effectively waterproof and allows to sail long. I tried it on a river for 4 hours and the only fault is the reduced dimentions. On the other hand, it is so small that it returns whole in my car.
This canoe is very fun but must be optimized to use it regularly. The back is too far back to be comfortable. The shape and dimensions make it not stable and sinks too much into the water.
I think a little bigger and stable, this canoe would be appreciable because it is very light and really cheap
The advantage is that it is a disposable canoe, you can make one or more and throw them after use because it does not cost much. If you are on vacation, you can make on the spot with only a saw blade as a tool then when you want to go home you put it in a trash. Mine cost me 15 $
In this video, I am having fun with friends and my family at first, then I synthesized the manufacture in accelerated and I see myself sailing on the river.
STEP 1: Equipment
150 meter minimum of 50mm duct tape
10x 20mm pvc pipe
a 30mm extruded foam plate
12x Long plastic clamps
STEP 2: Framing
Look in the video, I show how to assemble the boat, but we do not see the beginning.
Assemble 5 whole tubes and securely assemble the ends together
Put a lot of tape by asking the pipes 1 by 1. Do not assemble them all at once, otherwise they risk slipping.
Cut pieces of tubes to spread the tubes and give the general shape of the canoe .
Tape to assemble the tubes together
STEP 3: Putting Reinforcements
You must place enough reinforcements to prevent the hull from deforming. The main efforts:
On the ground, because of the opposing forces of mass and archimedes' thrust. -on the coast. Stiffness must be high due to paddle movements
STEP 4: The Floor
Cut a sheet of foam to the shape of the floor and one for the back. Then fasten them with clamps.
The foam should rest on as many tubes as possible so that it does not break.
Drill the foam with a drill and hang it with clamps
STEP 5: Coating in Duct Tape
Apply the duct tape to make the shell, the strips must be straight and overlap by about 25mm.
Apply 2 layers of duct tape and strips along the length to protect the edges
STEP 6: Waterproof Skirt
Also put duct tape on the top of the canoe and overlap by about 25mm to prevent it from filling with water from the front and back .
35 Comments
logan789 6 years ago
Johnw742 6 years ago
PVC pipe and duct tape (the real stuff anyway) are both horrificallyy expensive.
Its far cheaper to build in stitch n glue ply and where is the fun in that-its already a well proven boatbuilding method
GeoffKastel 6 years ago
LukasFreeze 6 years ago
Nice built, but I must say I am shocked by the "take home message" from the introduction! Just because something is cheap to make doesn't mean it's a good idea to trash and replace it whenever it gets inconvenient to transport, especially when it completely consists of materials that will take ages to break down :-(
Not saying it's not okay to throw something out now and then, but reading that statement made me cringe...
Marc Gyver 6 years ago
Sorry to shock you but this boat weighs around 3 kg of recyclable material.
On average, a Frenchman throws 350kg of waste per year. Not to mention professional waste. However I do not encourage to make them to throw them, it is only by way of example
JohnC430 6 years ago
and the average american throws away more than 1 ton of waste material
Science deserves a few kilograms of waste ;)
deluges 6 years ago
Except this aint science
Did you know that this duct tape was sufficiently waterproof to be able to realize a boat with? Otherwise, you've learned something, so it's knowledge, so by translation, of science. If you do not learn anything with my instructables, others do. Instructables is a site focused exclusively on science and sharing. Thank you for avoiding this kind of comment.
deluges 6 years ago
First:
https://www.instructables.com/id/Duct-Tape-boat/
https://www.instructables.com/id/Cardboard-and-Duc...
https://www.instructables.com/id/Duct-Tape-Boat-v1...
https://www.instructables.com/id/Duct-Tape-Boat-v2...
https://www.instructables.com/id/Duct-Tape-Kayak/
https://www.instructables.com/id/Duct-Tape-and-PVC...
https://www.instructables.com/id/Duct-tape-and-Car...
https://www.instructables.com/id/PVC-AND-DUCT-TAPE...
I'll stop here, there's probably a hundred more. So yeah - I knew.
Second:
From instructables.com/about : "Instructables is a place that lets you explore, document, and share your creations". No mention of science, I'm therefore a bit confused as to how you extrapolate that it's a website focused exclusively on science? You can take a look at, for instance, the cooking or woodworking section (or the duct-tape section for all that matters) and think about whether you think that the vast majority of the projects are part of "a systematic enterprise that builds and organizes knowledge in the form of testable explanations and predictions about the universe". I personally don't think so. It's a lot of tinkering, and it goes great places but there is no scientific method.
Now I didn't mean anything mean with my comment. I can see how it could have been rude. My bad. Take it however you want, what I meant is I think that what you're doing is mostly tinkering. Fine tinkering, I'm sure. I just don't think you're using the right argument to make your point.
I don't want to get in an argument about what makes science or what the ontology of scientific objects is, because I'm not sure myself. And I'd rather not have this kind of discussion on a comment board, but you're french so you can pm me and we can talk on the phone. I'd be happy to discuss it, for realskies.
So please accept my apologies if my comment seemed rude, I should have added "in my opinion" at the beginning but I typed it fast on my phone. I'll reformulate:
"I do not think that building a duct-tape canoe qualifies as science, and I don't like that people encourage making one-time use things. It's wasteful and I try to fight this. I didn't like it when Hitler (godwin point!) used "science" to justify his genocides, and I don't like that you use it as an excuse to justify throwing away a couple pounds of plastic when you haven't made global knowledge progress even an iota.
Yours truly,
Just a guy online"
B1u1d1d1y1 6 years ago
really enjoyed it except for the 'trash' concept. I always come home with my kayak festooned in junk I have picked out of the water,lodged in deadwood or disgracing the shore. Really try to reuse and leave no trace. Otherwise, wonderfully creative. Is the interior sticky?
Of course, I intend to reuse it and above all improve it. The inside is sticky to allow me futur modifications
cool idea. really nice job.
dfabian 6 years ago
Nice! This will be my next rainy-day project. Might sound dumb, but: I'm not very big (5'3", about 110), so would it still be necessary to construct a larger boat?
The dimensions of mine are made for a person of maximum 60 kg.
SaralynnJ 6 years ago
BTW this has been tested by the Mythbusters and confirmed it will work.
https://www.youtube.com/watch?v=FnILEXnRHP0
DreamDabbler 6 years ago
This encourages me to proceed with my plans to try making a double pontoon boat using plastic milk jugs and PVC piping. I think I will want to use something besides duct tape to hold things together, as I want to be able to take it apart and put it together again easily. Some sort of plastic adjustable clamps, perhaps, and heavy-duty plastic bags to help keep the jugs together and give a unified, smoother hull.
DelaL1 6 years ago
marian39 6 years ago
Yes it is a kayak. Not bad but a lirtle deeper and wider. Yes life jacket needed!
