Introduction: Duct Tape Desk Organiser File
How to make a cool organiser file for your desk which has all your bits and bobs in one place! Really easy to make, and I wish I had some cool colours and patterns of duct tape, but I only have grey and black. Enjoy!
Step 1: What You Need
You will need:
Anything you want to put in the organiser, and
duct tape ( x2 )
scissors
toiled roll
double sided tape
ruler
cardboard (choose the size you want)
Step 2: Getting the Cardboard Ready
Down the centre of the cardboard mark out a 3-4 centimetre strip using a ruler and a pencil. Band the cardboard carefully along the lines. This makes the spine.
Cover the inside and outside sides in one colour of duct tape. Do the spine in a different colour.
On the front cover put on some of the spine coloured tape and write on sharpie your name or what you want to call the organiser.
Step 3: Containers
First way to attach supplies: Containers.
Find a suitable container (mine was the packaging for some neon gel pens) and cut a strip of duct tape long enough to go round the container once.
Put the duct tape on the front of the container and down 2 sides, then stick the rest to the file.
Using a sharpie, write down what you are going to put inside the container on the duct tape.
Step 4: Pockets
2nd way to attach supplies: Pockets
Stick 2 strips of duct tape together. One should be longer that the other. Trim the shorter one so that it is not as wide as well. When you stick them together, put the smaller one right to the top in the middle of the bigger one, and stick the sticky sides together.
Put the inside around your supply and stick the sticky bits of duct tape onto the file. Remember to make sure that the sides and bottom have all stuck on properly.
Step 5: Double Sided Tape
3rd way to attach supplies: double sided tape
This way is used for attaching notebook, sticky notes, and other things like that.
Just put some tape over the back of the object, peel off the backing, and stick it firmly onto the file.
Step 6: Finishing Touches
Add the supplies into the pockets and containers, make sure the file can close and............
ALL DONE!!!!!!!
Enjoy your new desk organiser!
If you want to, please comment and vote for me in the duct tape contest!
