Duct Tape No-Sew Tote
Intro: Duct Tape No-Sew Tote
Make this unique duct-tape and fabric tote with absolutely no sewing - no kidding! This project, inspired by the awesome book Simply Sublime Bags by Jodi Kahn, takes less than an hour to whip up, and will garner oohs and ahhs from all who see it!
With a few simple supplies (get your stapler loaded!), a little time, and absolutely no prior experience needed, you can make your own gorgeous custom tote bag today!
STEP 1: Materials
You'll need:
- Fabric - something a bit sturdy works better. I used a donation scrap of what I think was upholstery fabric. I made the bag as big as the scrap would allow, which turned out to be 10"x18"
- Duct tape - get a color you like to coordinate with your fabric. This was my first go, so I just used what was around. The next one will get something fancy!
- Scissors to cut your fabric
- Stapler + staples (oh yes)
- *Optional (but awesome) - two tiny strong magnets
STEP 2: Cut Fabric
Whatever size you decide to go with fold the fabric in half vertically.
- Cut two squares out of the bottom corners, about 1" high and 1 1/2" wide. If you make a bigger bag, or want it to be wider at the base, increase these measurements.
STEP 3: Tape
- Open the fabric, party side down.
- Start layering strips of duct tape over the wrong side (inside) of the fabric, slightly overlapping each strip.
- Continue until piece is covered.
- Trim away excess tape
STEP 4: Cut Handle Opening
Now you're going to mark where the opening for your handle will be. In this instance, I made a 4"x1" opening, centered near the top. This is how:
If you ever have sewn, you may recognize how much these look like welt pockets or bound buttonholes.
- Fold the fabric in half, party sides together, to mark the center on the tape, 1 1/2" down from the top.
- Draw a line 2" to each side of this mark, and 1"down on each side. Finish the box by drawing the bottom line.
- Mark a line horizontally across the center of the box.
- Make a mark 3/4" in from each side on this line.
- Draw diagonal lines from the corners to these marks.
- Repeat on other end.
STEP 5: Make Handle
Now we make the handle.
- Cut carefully along the new lines you've made.
- Fold back the flaps and secure with pieces of tape
- Repeat on other handle
STEP 6: Finish Top Edge
You want to turn the top 1/2" of fabric to the inside and tape down. I did it this way:
- Lay a piece of tape to cover 1/2" of the top edge on the party side of the fabric.
- If you're using magnets as a latch, insert them under the tape in the center of the top edge
- Fold this edge over to the inside and tape down.
- Trim away the tape covering the handle opening.
- Repeat on other side, making sure magnets are in correct alignment.
STEP 7: Staple Together
Now we make the "seams."
- Fold fabric in half, right sides together
- Staple the sides of the bag 1/2" in from the edge.
- Clip the corners at the top.
- Repeat on other side.
STEP 8: Tape Over Edges
Now we'll seal the raw edges.
- Using a block or book inside, press the seam allowance open with your fingers.
- Cover the edges with tape and trim.
STEP 9: Close Bottom Corners
Close the bottom of the bag at the corners by matching up the raw edges.
- Staple together 1/2" in from edge.
- Fold seam allowance toward the bottom of the bag and cover with tape.
- Trim and fold edges for a clean finish.
STEP 10: Turn Tote Right Side Out
Well, that's pretty self-explanatory.
- Turn bag right side out.
- Test out your awesome magnets.
- Fill it with goodies.
- Send some to me.:)
72 Comments
sdpiphi 11 years ago
DeandrasCrafts 11 years ago
curlyFSU 12 years ago
isandy 12 years ago
scoochmaroo 12 years ago
masynmachien 13 years ago
I made one for my good friend Kleenie's birthday. I added some duct tape roses (she's very fond of red roses). I wrapped the roses on some M3 nuts mounted on a bolt, removed the bolt and cut a flat bottom end to each rose. Then I attached each rose to the back of a snap fastener half with the bolt. I put in a washer in between an carefully added a drop of superglue to lock the thread and add strength to the attachment.
scoochmaroo 13 years ago
piccolo1979 13 years ago
alix-cool 13 years ago
crzychique 15 years ago
scoochmaroo 15 years ago
trepanier.carole.7 9 years ago
I AM obviously clumsy! I just did not read it 'till the end! GREAT tutorial! I'm making one... at least!!!! Thank you!
I adore this idea! Maybe i'm a bit clumsy but... Where do the staples come in?
Thank you!!!
tonyssn639 9 years ago
marydecorator 10 years ago
Thanks for sharing. These are look really neat! I'm a big fan of duct tape and I'm sure to try it out soon. :) I read in another comment about sewing instead of stapling and you advised against it because it could jam up the machine. How about hand sewing then, do you think that could work?
creative_aarya 10 years ago
I have been to instructables numerous time before. But only today created an account just to let you know that I love this tutorial and I am sure I'll be trying it pretty soon.
I love the idea of duct tape as lining. If done neatly, this could be a convertible tote - for beach, for shopping or just as a stylish bag to carry your stuff around.
scoochmaroo 10 years ago
Well that is just so sweet. Thank you!
sprekeges 10 years ago
