Introduction: Duct Tape Zune Case
Hello out there all my diehard zune fans!!!
I'm going to show you how to make a VERY simple zune case for the smaller 4-16 gig sizes
I also will include how to make custom sticker decals for this case!
Step 1: Materials!!!
For materials you will need,
1. your Zune (4, 8 or 16 gig sizes)
2. Duct tape
3. Packaging tape
4. exacto knife
5. a solid sheet of sticker paper
THREE, FOUR, AND FIVE ARE IF YOU WANT A CUSTOM DECAL ONLY!!!
2. Duct tape
3. Packaging tape
4. exacto knife
Step 2: Duct Tape # 1
First, take your duct tape roll and measure a piece that is twice as long as your zune ( long as in vertical )
Next, tear another piece off that is the same size than the first one.
Finally, stick the two same sized pieces together so that you get one solid piece of duct tape with two sides.
Step 3: Duct Tape # 2
Now, fold the strip of duct tape in half ( make sure that when it's folded in half that it is mostly the same size as your zune!!!)
Next, measure out a piece of duct tape that is the length of your zune, or the length of the long strip folded in half.
Then, tape up one side of the strip that is folded in half to get something like the last picture.
Step 4: Duct Tape # 3
Repeat the last step except with the other side to get you finished Zune case!!!
YOU ARE DONE IF YOU DON'T WANT CUSTOM DECALS GOOD JOB.
If you want CUSTOM DECALS, go on to step 5.
Rate high!!! pls
Rate high!!! pls
Step 5: Custom Decal Time........YEYZ!!!
Ok, got your solid sticker sheet, packaging tape, and exacto knife!!!
first, go online and print some cool image. (I chose flames)
(make sure they are about the same size as the case)
now, take your sticker sheet, decal picture, and exacto knife.
place your picture on top of the sticker sheet and cut around the object in the picture ( make sure that you cut all the way through all of the layers!
peel the cutout out and you should have a sticker decal for your case!
Step 6: Now to Make the Sticker Stick Forever
Rip a peice of packaging tape off that is twice as long as your Zune.
Cover the sticker and the case whole.
YOUR FINISHED YEY :D
I don't have any pics for this sry!!!
Step 7: DONE
Now, the zune may fit too tight at first, but the duct tape will stretch after a while
Rate this high for more creative zune cases from Bobert 610!!!
