Duel of the Fate
Intro: Duel of the Fate
This is a pong game works on Processing with two Arduino potentiometer as controller.
STEP 1: Circuit Example
Arduino UNO x 1
Mini breadbaord x1
Potentiometer x 2
Wires x 12
STEP 2: Example Code for Arduino
In this project you will need to code in both Processing and Arduino.
For Arduino
int secondSensor = 0; // second analog sensorint firstSensor = 0; // first analog sensor
int inByte = 0; // incoming serial byte
char val; void setup() {
// start serial port at 9600 bps: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } pinMode(2, OUTPUT); // digital sensor is on digital pin 2
establishContact(); // send a byte to establish contact until receiver // responds
} void loop() {
// if we get a valid byte, read analog ins: if (Serial.available() > 0) { // get incoming byte: inByte = Serial.read();
// read first analog input, divide by 4 to make the range 0-255: firstSensor = analogRead(A0) / 4; // delay 10ms to let the ADC recover: delay(10); // read second analog input, divide by 4 to make the range 0-255: secondSensor = analogRead(1) / 4; // read switch, map it to 0 or 255L // send sensor values: Serial.write(firstSensor); Serial.write(secondSensor);
} void establishContact() {
while (Serial.available() <= 0) { Serial.print('A'); // send a capital A delay(100); } }
STEP 3: Example Code for Processing
For Proccessing
// This example code is in the public domain.
import processing.serial.*; int bgcolor; // Background color int fgcolor; // Fill color Serial myPort; // The serial port int[] serialInArray = new int[3]; // Where we'll put what we receive int serialCount = 0; // A count of how many bytes we receive int apos, bpos; // Starting position of the player int p1score=0; // Score int p2score=0; boolean start=false; // The status of game boolean p1goal=false; boolean p2goal=false; boolean Gameover=false;
boolean Hit=false; boolean Goal=false;
ball b; Letter l; Number n; Score s;
boolean firstContact = false; // Whether we've heard from the // microcontroller void setup() { size(500, 305); // Stage size noStroke(); // No border on the next thing drawn // Set the starting position of the ball (middle of the stage) apos = width/2; bpos = height/2; b= new ball(); l= new Letter(); n= new Number(); s= new Score();
// Print a list of the serial ports, for debugging purposes:
// I know that the first port in the serial list on my mac // is always my FTDI adaptor, so I open Serial.list()[0]. // On Windows machines, this generally opens COM1. // Open whatever port is the one you're using. String portName = Serial.list()[0]; myPort = new Serial(this, portName, 9600); } void draw() { background(bgcolor); fill(255); // Draw the shape rect(30, apos, 20, 60); rect(470, bpos, 20, 60); b.balldraw(); b.ballcheck(); s.display(); s.check();
} void serialEvent(Serial myPort) { // read a byte from the serial port: int inByte = myPort.read(); // if this is the first byte received, and it's an A, // clear the serial buffer and note that you've // had first contact from the microcontroller. // Otherwise, add the incoming byte to the array: if (firstContact == false) { if (inByte == 'A') { myPort.clear(); // clear the serial port buffer firstContact = true; // you've had first contact from the microcontroller myPort.write('A'); // ask for more } } else { // Add the latest byte from the serial port to array: serialInArray[serialCount] = inByte; serialCount++; // If we have 3 bytes: if (serialCount > 2 ) { apos = serialInArray[0]; bpos = serialInArray[1]; fgcolor = serialInArray[2]; // print the values (for debugging purposes only): println(apos + "t" + bpos + "t"); // Send a capital A to request new sensor readings: myPort.write('A'); // Reset serialCount: serialCount = 0; } } }
STEP 4: Example Code for Processing (2)
class ball {
float x=250; // Starting position of the ball float y=150;
float xspeed=3; // Speed of the ball float yspeed=3;
void balldraw() { fill(255); rectMode(CENTER); rect(width/2, height/2, 6, height); rectMode(CORNER);
if ((keyPressed)&&(key==CODED)) { //Press UP to start the game if (keyCode==UP) { if (Gameover==false) { start=!start; } } }
if (start==false) { fill(255); x=250; y=150; ellipse(width/2, height/2, 30, 30); } if (start==true) { fill(255); ellipse(x, y, 30, 30); x=x+xspeed; y=y+yspeed; } } void ballcheck() { if (y<15) { yspeed=-yspeed; } if (y>290) { yspeed=-yspeed; }
if (x>485) { start=false; p1score+=1; p1goal=true; Goal=true; } if (x<15) { start=false; p2score+=1; p2goal=true; Goal=true; }
if ((x>45)&&(x<65)&&(y>apos-15)&&(y<apos+75)) {<="" p=""></apos+75))>
xspeed=-xspeed;
Hit=true; } if ((x>450)&&(x<470)&&(y>bpos)&&(y<bpos+75)) {<="" p=""></bpos+75))>
xspeed=-xspeed; Hit=true; } if ((x>40)&&(x<width-<width-40)&&(y style="background-color: initial;">40)&&(y>40)&&(y<height-40)){Hit=false;}</width-40)&&(y>
<width-40)&&(y style="background-color: initial;">}</width-40)&&(y>
<width-40)&&(y style="background-color: initial;"><p>class Score{</p><p>void display(){ if(p1score==0){n.Zero(width/2-15,15,2);} if(p1score==1){n.One(width/2-15,15,2);} if(p1score==2){n.Two(width/2-15,15,2);} if(p1score==3){n.Three(width/2-15,15,2);} if(p2score==0){n.Zero(width/2+12,15,2);} if(p2score==1){n.One(width/2+12,15,2);} if(p2score==2){n.Two(width/2+12,15,2);} if(p2score==3){n.Three(width/2+12,15,2);} }</p><p>void check(){</p><p> if(p1score==3){ l.P(width/2-42,105,8); n.One(width/2+40,105,8); l.W(width/2-46,180,8); l.I(width/2-4,180,8); l.N(width/2+38,180,8); Gameover=true; } if(p2score==3){ l.P(width/2-42,105,8); n.Two(width/2+40,105,8); l.W(width/2-46,180,8); l.I(width/2-4,180,8); l.N(width/2+38,180,8); Gameover=true; }</p><p>}</p><p>}</p></width-40)&&(y>
STEP 5: Example Code for Processing (3)
For Processing (3)
This part is unnecessary, but I still use this way in my code. If you can use text function, you can ignore this part and fix the code on your own.
class Letter {
void A(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x, y, p, p); rect(x-p*1, y+p*1, p, p*4); rect(x+p*1, y+p*1, p, p*4); rect(x, y+p*2, p, p); } void B(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x-p*1, y, p*2, p); rect(x-p*1, y+p*2, p*2, p); rect(x-p*1, y+p*4, p*2, p); rect(x+p*1, y+p*1, p, p*3); } void C(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y+p*1, p, p*3); rect(x, y, p*2, p); rect(x, y+p*4, p*2, p); } void D(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x, y, p, p); rect(x+p*1, y+p*1, p, p*3); rect(x, y+p*4, p, p); } void E(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x-p*1, y, p, p*5); rect(x-p*1, y+p*2, p*3, p); rect(x-p*1, y+p*4, p*3, p); } void F(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x-p*1, y, p, p*5); rect(x-p*1, y+p*2, p*3, p); } void G(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x-p*1, y, p, p*5); rect(x-p*1, y+p*4, p*3, p); rect(x+p*1, y+p*3, p, p); } void H(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x+p*1, y, p, p*5); rect(x, y+p*2, p, p); } void I(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x, y, p, p*5); rect(x-p*1, y+p*4, p*3, p); rect(x-p*1, y, p*3, p); } void J(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x+p*1, y, p, p*4); rect(x, y+p*4, p, p); rect(x-p*1, y+p*3, p, p); } void K(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x, y+p*2, p, p); rect(x+p*1, y, p, p*2); rect(x+p*1, y+p*3, p, p*2); } void L(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x-p*1, y+p*4, p*3, p); } void M(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x+p*1, y, p, p*5); rect(x, y+p*1, p, p*3); } void N(float x, float y, float p) {
rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x+p*1, y, p, p*5); rect(x, y, p, p); } void O(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x-p*1, y, p, p*5); rect(x+p*1, y, p, p*5); rect(x-p*1, y+p*4, p*3, p); } void P(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x-p*1, y, p*3, p); rect(x+p*1, y, p, p*3); rect(x-p*1, y+p*2, p*3, p); } void Q(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x-p*1, y, p, p*4); rect(x+p*1, y, p, p*4); rect(x-p*1, y+p*3, p*3, p); rect(x+p*1, y+p*4, p, p); } void R(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*5); rect(x-p*1, y, p*3, p); rect(x+p*1, y, p, p*3); rect(x-p*1, y+p*2, p*3, p); rect(x, y+p*3, p, p); rect(x+p*1, y+p*4, p, p); } void S(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x, y, p*2, p); rect(x-p*1, y+p*1, p, p*2); rect(x-p*1, y+p*2, p*3, p); rect(x+p*1, y+p*2, p, p*2); rect(x-p*1, y+p*4, p*2, p); } void Y(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*3); rect(x+p*1, y, p, p*3); rect(x, y+p*2, p, p*3); }
void V(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p, p*4); rect(x+p*1, y, p, p*4); rect(x, y+p*3, p, p*2); } void W(float x, float y, float p) { rect(x-p*1, y, p, p*5); rect(x+p*1, y, p, p*5); rect(x, y+p*2, p, p*2); } }
class Number {
void Zero(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*1, y, p*3, p); rect(x-p*1, y, p, p*5); rect(x+p*1, y, p, p*5); rect(x-p*1, y+p*4, p*3, p); } void One(float x, float y, float p) {
rect(x, y, p, p*4); rect(x-p*1, y, p, p); rect(x-p*1, y+p*4, p*3, p); }
void Two(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*2, y, p*3, p); rect(x, y, p, p*3); rect(x-p*2, y+p*2, p*3, p); rect(x-p*2, y+p*2, p, p*3); rect(x-p*2, y+p*4, p*3, p); }
void Three(float x, float y, float p) { rectMode(CORNER); fill(255); rect(x-p*2, y, p*3, p); rect(x, y, p, p*3); rect(x-p*2, y+p*2, p*3, p); rect(x, y+p*2, p, p*3); rect(x-p*2, y+p*4, p*3, p); } }
