Introduction: DIY Duffle Handbag (EASY)
How to make duffle handbag sewing pattern. Fun sewing project for all skill levels
-LINK to Pattern:
-LINK to Fabric(canvas): https://amzn.to/3ErHxoB
-LINK to Fabric(denim): https://amzn.to/3lKEwY2
-LINK to Vinyl: https://amzn.to/2Yuxw9X
-LINK to Leather: https://amzn.to/3mxchwg
-LINK to Zipper: https://amzn.to/3oESLk3
-LINK to Zipper Presser Foot: https://amzn.to/3afmI1C
-LINK to Edge Presser Foot (domestic machine): https://amzn.to/3wCxWqf
Step 1: Supplies
Main Fabric: 2 yards (canvas, denim, twill)
Lining: 2 yards (cotton)
Vinyl/leather: 20x4IN (2)
Zipper: 22IN (1)
Printable Sewing Pattern
Step 2: Assembling Pattern
- Download pattern.
- Print pattern.
- Tape pattern together alphanumerically from left to right, top to bottom.
- Choose garment size.
- Cut out pattern.
Step 3: Pattern Pieces
After cutting you should end up with.
- Zipper end panel - 2
- Main side pocket panel - 2
- Bottom panel - 1 outer layer and 1 lining
- Side panel - 2 outer layer and 2 lining
- Strap A, and B - 2 of each
- Main Panel - 2 outer layer 2 lining
Step 4: Mark Pattern Guides
-Mark the guides indicated on pattern
-This will help line up pocket and straps.
Step 5: Prepare Pocket
-Fold top edge on guide line (about .5 inch)
-Fold over twice hiding raw edge.
-Iron edge after folding.
-Repeat process for other pocket panel.
Step 6: Pocket Placement
-Grab main panel and pocket panel.
-Using the marked guides. Place pocket between straps lining up the bottom edge.
-Sew as close as you can top the outside edge.
Step 7: Adding Zipper to Half Main Panel
-Grab your zipper and main panel (1 outer layer and 1 lining)
-Place the right side of the zipper to the top edge of the main outer layer.
-Place the lining layer directly over zipper. Sandwiching zipper in between the 2 main layers.
-Using a zipper presser foot.
-Sew all layers together.
Step 8: Top Stitching Zipper Edge
-Pull wrong sides of main panels together.
-Using edge presser foot.
-Top Stitch zipper edge.
-I recommend using matching color thread for best results.
Step 9: Repeat for Opposite Main Panel
-Repeat the previous steps for the other 2 main panels on on the opposite side of the zipper.
-Sandwich zipper in between panels.
-Sew together.
-Add top stitch along zipper edge.
Step 10: Preparing Zipper End Panels
-Fold zipper end panels on indicated marks.
-Iron for best results.
Step 11: Zipper End Placement
-Place folded zipper end on the outside edge covering zipper.
-Make sure the raw edges of the zipper end are pointing to the outside.
-Sew the top and bottom edge.
-Repeat for opposite side. BUT be sure to pull the zipper in before sewing.
Step 12: Preparing Straps Part 1
-Grab both A and B strap panels
-Using the guides indicated on the pattern place the wrong sides of A and B together.
-It is easiest to use spray adhesive to keep panels lined up for sewing.
-Sew around outside edge of Strap Panel A.
Step 13: Preparing Strap Part 2
-When the panels are sewn together.
-Trim excess fabric from strap panel B.
-Trim as close as you can to strap panel A.
Step 14: Adding Straps to Main Panel
-Grab complete straps.
-Place straps on marked guides on the main panel.
-Use spray adhesive so keep straps in position for sewing.
-Sew out side edge of strap up to zipper. This is indicated on the main panel.
-Repeat process for both straps.
Step 15: Adding Bottom Panel
-Grab bottom panel.
-Place the right sides together for bottom panel and bottom edge of main panel. This will be the opposite edge of the zipper.
-Sew at .25 inch seam allowance.
-Trim excess strap material after sewing.
Step 16: Top Stitch Bottom Edge
-After sewing bottom edge.
-Move away from the main panel.
-Add top stitch.
Step 17: Opposite Bottom Edge
-Repeat previous steps for opposite edge of bottom panel.
-Line up the opposite edge of bottom panel with the opposite main panel.
-Trim excess strap material.
-Top stitch seam.
Step 18: Repeat Previous Steps for Lining
-Grab the lining bottom panel.
-Place right side of lining bottom panel to main panel.
-Repeat for opposite edge of bottom panel and main panel.
Step 19: Lining UP
-Grab the completed lining panels and place them on the inside of the outer layers.
Step 20: Side Panels
-Grab all of the side panels.
-Mark the center of top and bottom.
-Place the wrong sides together for outer layer and lining.
-Line up to main panel edge.
-Top center should line up with zipper.
-Stitch at .25 inch seam allowance around entire edge.
Step 21: Snip Zipper
-Snip the excess zipper sticking out of the side panel.
Step 22: Choose Bias Tape Option
-We need to bias tape the side panel edge.
-This will clean up the edge and make for a more professional look.
- Premade bias tape
- Bias tape making kit
- Bias tape binder.
Step 23: Premade Bias Tape
-Premade bias tape can be bought at the craft store and it is a simple solution.
-Place the raw edge in between the bias tape and sew down.
Step 24: Bias Tape Making Kit
-Bias tape is installed same as the premade.
-The kit allows you to make your own matching bias tape.
-You also get to pick the size and it comes with a presser foot for easy installation.
-Feed your bias tape strip through the feeder and iron on the opposite side.
-It is really that simple.
-Once bias tape is made. Install it on bag.
Step 25: Bias Tape Binder
-This is my favorite option.
-It is the easiest because it eliminates the process of making the bias tape.
-Place bias strip into binder and sew directly onto the edge of bag.
Step 26: Finished!
-Flip the right sides out and you are finished!
Hope everyone enjoys this project! I will as post a detailed step by step video if you get stuck.
Thank you so much for checking out my sewing project!
Step 27: Detailed Video
-If you get confused about any step please feel free to watch the detailed instructional video :)
