Introduction: Duncan Reflex Auto Return Yo-Yo Mod
In this instructables I will be showing you how to mod your Duncan Reflex Auto Return so it acts more like a butterfly Yo-Yo.
If you want another mod that does the same thing but but works better for your Duncan Reflex Auto Return Yo-Yo, go to my other instructables "Duncan Reflex Auto Return Yo-Yo (Permanent)"
Step 1: What You Will Need
You will need...
A Duncan Reflex Auto Return Yo-Yo
A Screw Driver
A Screw Driver
Step 2: Step 1: Unscrew Your Yo-Yo
Unscrew your Yo-Yo and take out the plastic axle.
Step 3: Step 2:
Take of the ring on the end of the plastic axle.
Step 4: Step 3: Unscrew the Screws
Unscrew both screws on the side of the Yo-Yo that has the machine.
Step 5: Step 4: Push Out the Caps
To push the caps out put a screw in the screw hole and push. Do this to both screw holes.
Step 6: Step 5: Take Out Machine
Carefully take out the machine with a screwdriver and put it somewhere safe where you won't lose it.
Step 7: Step 6: Oil and Reassemble
Put oil inside of your plastic axle and the put your Yo-Yo back together. It will act as a butterfly Yo-Yo now! If you don't like this mod you can just put the machine and the ring back on and have an auto return Yo-Yo again.
