Introduction: Duncan Yo-Yo Hack (1 Into 2)
In this instructables I will show you how to improve your Duncan butterfly
Yo- Yo and make another Yo-Yo in the process.
Step 1: Gather Your Materials
You will need...
A Duncan Yo-Yo
A small screwdriver or knife
Super glue
String
Scissors
(Optional) Lighter
A Duncan Yo-Yo
Super glue
String
Scissors
(Optional) Lighter
Step 2: Take Off the Cap
Take a small screw driver or knife and carefully pry off the cap of the Yo-Yo on each side. There is what looks like a bubble where the notch that you pry it off with is.
Step 3: (Optional) Light Rough Edges Edges
If there are rough edges on the cap or your Yo-Yo you can melt them down.
Step 4: Glue the Caps Together
Super glue the notches on the insides of the caps together.
Step 5: Add the String
1. Cut the string from your hips to the ground and add 4 inches.
2. Tie a loop in each side.
3. Make a slip knot by making a loop and putting it through the tied loop.
4. Put the slip knot around the Yo-Yo.
Step 6: Add Weight
Add two washers to the cap Yo-Yo in the center of each side. This adds weight to make it go better, and it makes it look cool.
Step 7: Play With Your New Yo-Yo
Your done. You have Made a Yo-Yo and also improved your original Yo-Yo by taking away weight and making it more controllable.
