Introduction: Duplicating a Remote
In this instructables I will show how to create a copy of any IR Remote to phone using Arduino
This can be used to make duplicates of any IR Remotes
Arduino UNO (or any arduino)
IR Reciever TSOP1838 ( or any other IR reciever)
Jumper wires
A Smartphone with IR Blaster
Step 1: Program the Arduino
For this you will need Arduino IDE and the IRRemote library
Arduino IDE : https://www.arduino.cc/en/Main/Software
IRremote Library: https://github.com/z3t0/Arduino-IRremote
Download and install IRremote library
Now connect the Arduino to PC
Then click File > Examples > IRremote > IRrecvDumpV2
Select the Correct Board Type and port in the tools menu
Now Click upload and wait for the process to finish
Step 2: Set Up the Circuit
Now connect the reciever to arduino according to the schematics given above
Note:- The pinout of the reciver can vary check on internet for correct pinout for your reciever. Connecting the reciever incorrectly can damage it
OUT --> Arduino pin 11
VCC --> Arduino 5V
GND --> Arduino GND
After connecting everything connect Arduino to PC and open serial monitor
Step 3: Install the Irplus App and Create Remote
Download the irplus app on your phone
irplus : https://play.google.com/store/apps/details?id=net....
After installing the app open the app
In the menu tap on ADD
Now select a remote
here I choose NEC from the Brand and leave the rest as default
Click the tick on top right corner
Now you will get a remote with some buttons
To edit select menu > edit
You can move the buttons by tap and draging it
You can edit the button by tapping it
To delete a button drag it to the recycle icon on top
To create a button drag the new button icon into the remote
After editing the remote click on the tick on top right corner
Step 4: Export the Remote
After creating the remote layout we need to export it
on irplus app tap menu > export
then choose file
then choode a location and export
Now connect your phone to PC and copy the exported file to a location on PC ( eg: Desktop)
Step 5: Clone the Remote
Now we have the layout file we need to add the ir codes from the remote
This layout file uses a format called WINLIRC
To get the ir codes, take the remote you want to copy
Point it at the arduino reciver and press a button
Now you'll see the output on the serial monitor
It's lengthy
you dont need the whole output
In the output you'll see a line starting with " unsigned int rawData "
Copy everything inside the brackets and paste it into a text editor
Now remove all coma ( , ) from the text
An easy way for this would be to use the "Find and Replace" in the text editor
Now you'll have a bunch of space seperated numbers
open the exported file and copy this number into the button tag as shown in the image above
Repeat this steps for all the buttons
after doing it for all button save the file
Step 6: Import the Remote
Connect your phone to PC and copy the Edited irplus file to the phone
Open ir plus app and delete the existing remote
Menu > REMOVE > OK
Now import the edited file into the app
Menu > IMPORT > FILE
and choose the edited file
Now the remote is ready to use
Step 7: Final
I hope you find this instructable interesting
Also this instructable is on Arduino contest
please vote
Thank you
