Introduction: Dutc Tapes Bottle Pouch
Make a cool bottle pouch
For a plastic, glass, or metal bottle
I made for my vodka bottle.
Step 1: Search the Materials and Tools
What we need here is
- Bottle (in this case I choose my vodka bottle)
- Duct Tape (any color. feel free to explore your ideas and creativity)
- Scissor
- Ruler
- Cutter
- Pen or Permanent marker
Paper (used paper low cost or even free) to make a bottle pattern
Step 2: Making a Pattern
first, wrap the bottle with some paper to make a shape of the bottle and mark it with marker.
then, cut the paper off, now you have the pattern of the bottle.
make pattern with the duct tape that similar to the paper pattern you made before.
Use a ruler to make a better pattern and cut the unnecesary parts.
Step 3: Duct Tape the Pattern
apply the pattern to the bottle and tape it.
duct tape the each side of the bottle don't strap it to tight so the bottle is easy to remove.
duct tape the inside of the pouch to cover up the sticky part so the bottle can be remove smoothly.
Step 4: Half Done...
after you duct taped each side of the pouch you need to make the bottle holder so is wouldn't pop off accidentally.
make sure the holder can loop easily above the bottle neck.
add a clip on the pouch and the loop.
Step 5: Belt Holder for the Pouch
duct tape the back of the bottle cover the center left only the upper and the bottom part.
strenghten the upper and the bottom part with duct tape. it will hold the pouch as you take the bottle out of it.
Step 6: Finishing Touch..
make sure you cover all the sticky part (just cover it with the duct tape or cut it), add more duct tape to make it durrable.
you can make an ornament picture or even put your name on the pouch. (use your creativity)
then you have you own DIY duct taped bottle pouch.
