Introduction: E-Waste Keychain
Hello, this instructable the intention is to provide more insight into how to reuse your junk!
the motherboards I took another instructables (this:E-Waste Speaker)
However, the steps are pretty much the same.
The difference is that the keychains is smaller and you can make the most of their boards to make them, at the end of it all, what do left is virtually dust! hehehe
Olá, neste instructable a intenção é dar mais uma ideia de como reaproveitar o seu lixo eletrônico!
as placas mãe eu aproveitei de outro instructables( este: Caixa de som de E-Lixo)
porém, as etapas são praticamente as mesmas.
a diferença é que o chaveiro é menor e você poderá aproveitar ao máximo suas placas para fazer os chaveiros, no final de tudo, oque sobrou foi praticamente poeira! hehehe
Step 1: Cleaning the Motherboard's.
Tools required:
- Hot air blower;
- pliers;
- Screwdriver (to push the SMD components);
- PPE (Personal Protective Equipment in case the safety glasses);
Use the cards you had already cleaned if you made the E-Waste Speaker.
Ferramentas necessárias:
- Soprador de ar quente;
- Alicates;
- Chave de fenda (para empurrar os componentes SMD);
- E.P.I (Equipamento de proteção individual, no caso o óculos de segurança);
Utilize as placas que você ja tinha limpado caso tenha feito o E-Waste Speaker.
Step 2: Cutting the Boards.
I drew 3 keychains to be cut on the CNC, this CNC is computer science course the staff of the laboratory, with the length of about 50mm and 10mm high
Tools required:
- A CNC cutting machine;
- Some sandpaper;
- And of course, motherboards without the components;
- Without forgetting to use PPE (Personal Protective Equipment) and also to cut these boards can be dangerous to your health, always use an air cleaner to suck cutting powder.
NOTE: know that after cut keychains between letters will be copper burrs and can hurt, do not forget to sand and outside and between the letters!
Eu desenhei 3 chaverinhos para serem cortado na CNC, essa CNC é do laboratório do pessoal do curso de Ciências da Computação, com o comprimento de aproximadamente 50mm e 10mm de altura
Ferramentas Necessárias:
- Uma máquina de corte CNC;
- Algumas lixas;
- E é claro, as placas-mães sem os componentes;
- Sem esquecer de usar o E.P.I(Equipamento de proteção individual) e também que cortar estas placas pode ser perigoso para sua saúde, utilize sempre um Aspirador de Ar para sugar o pó do corte.
OBS: saiba que apos cortar os chaveiros entre as letras ficará rebarbas de cobre e pode machucar, não esqueça de lixar bem do lado de fora e entre as letras!
Step 3: Finalizing the Details.
Now just the details.
You will need:
- Spray varnish in general;
- Keychain rings;
- Cut pieces in CNC;
After that it's only joy! haha
Agora é só os detalhes.
Você precisará de:
- Verniz geral em Spray;
- Argolas de chaveiro;
- Peças cortadas na CNC;
Depois disso é só alegria! haha
