Introduction: EAL- Embedded - Combination Lock
This project is one school project, which I have made to choose subject 2.1 C-programming in the EAL. It is the first time, when I made an Arduino project and C-programming. That is a project, which presenter a combination lock. A combination lock can we use in many places every day. We can use that among other in the safe or when we need to open some door.
Step 1: Components
To at create that project, I have used the following components:
- Arduino mega 2560
- LCD 2x16 HD44780 blue
- Konverter LCD HD44780 I2C IIC
- SERVO Tower Pro SG92 9g
- Keypad 4x4 8pin
- Led blue
- Contact plade
- Connection wires
- Power bank
Step 2: Connection
The above picture and the following description presents how all components are connected to the Arduino Mega 2560.
LCD end KONVERTER - Arduino 2560 Mega
GND - GND
VCC - 5V
SDA - SDA
SCL- SCL
KEYPAD - Arduino 2560 Mega
conected A0 A1 A3 A4 A5 A6 A7
SERVO - Arduino 2560 Mega
GND - GND
VCC - 5V
SIGNAL - 8 Pin
Step 3: Programming
I have started programming in that way that I have found the library to LCD, password, keypad . Next, with help easy programs in Arduino I have checked, that my components working good. One of the biggest problem was, that converter has not communication with LCD. After one long day and evening I have found a problem. Problem was the wrong address in converter. Next step was to finish a program.
Keypad, I have used to entering the code. (1111)
Servo is working like an unlocking mechanism.
LCD is showing the code, which I have entered. (1111)
Program is working in that way that after I enter the correct code, the blue led lights up and servo performs a 90-degree movement.
Step 4: Testing
In the testing, I have entered code (1111), with I approved with the star. After I have entered the correct code on the LCD, I could see inscription OPEN, and the blue led lights up and servo make a 90-degree movement. When I have wrote a wrong code, I could see inscription WRONG.
The device is working properly and without any problems.
That is an easy project, which we can use in a lot of situation and places.
